- Thread starter
- #101
Just an update post with some pics and info of my progress.
First, got the fuel system completed.
I made new hard fuel lines using the old lines as a template, then modified as necessary for the in line fuel pump (old lines next to the new ones):
Couple pics installed:
And the fuel pump along the passenger side frame rail. I would have like to installed this closer to the tank (tank outlet is underneath on the the driver side, but just could not find a good spot.).
I got a gas pedal from an early year cruiser that seems to fit perfectly. I used on existing hole from the stock pedal, and drilled a hole for the other and for throttle cable to come in:
Wiring: If you read my thread, this was where I had the most questions. The nice thing was that the engine harness came with the engine, so I didn't have to do anything there, other than modify the connection point between the harnesses (my engine harness is an 89, but the main harness I obtained was an 88...the bridge between the two was different for those years...come to that in a minute).
Like others suggested, I started with the ECU connector on the FJ62 harness and traced and tagged every wire. I then pulled those from the rest of the harness:
Organized a bit:
I then fitted against the 40 harness to get an idea on lengths, and to figure out the points in which I needed to splice the ECU harness into the main 40 harness:
I then spliced all wires in. Wired up the new switched relay as per instructions/help from the guys earlier in this thread. No pic yet, but I will post as I think it might be helpful to others (this was the most confusing part for me as a guy new at this stuff).
As for the 88 to 89 harness bridge connector. My engine harness was fitted for an 89, which has a round 5 pin connector and a separate 2 pin connector. The 88 harness had one 7 pin connector. In order to mate the two, I obtained the male end of the 5 pin connector that I needed. Then cut the 7 pin connector and joined the necessary 5 wires to the 5 pin connector:
For the two remaining green wires, I still need to connect them.
I then put all the wiring in the cruiser to test fit, and also to get a few things connect. I wanted to see if I could at least get the engine to turn over (I did - so on the right track!). This is how it is now...a bit messy still...I want to tighten up the wiring and get the lengths exact and marked before I pull the harnesses to wrap it. I also need to figure out where to put another hole in the firewall as the current one is not big enough.
Also need to get rid of the unused stuff from the 40 harness (e.g. alternator connections, carb connections, smog stuff). What did others do here? Did you just cut and cap them, or completely remove them?
Organized a bit:
