- Thread starter
- #121
How do I check for power? I know I have continuity in the B-L wire from the battery connection to the relay pin, so I assume it is sending power. Is there a better way to verify?
That is a picture of the relay.
OK, I get why the relay. I guess I wouldn't trust old FJ40 wiring either. I used all FJ62 wiring from the dash so I was good without the relay.
Question, why not use a regular Bosch relay? That way you can get one anywhere if it goes bad. Easy to wire too.
I was in the same boat, 88 engine harness with two plugs and an 89 cowl harness with one plug. The 88 engine harness was pretty rough so I just went with a 89 engine harness and solved all the issues. I went out and looked at my partially disassembled 88 engine harness and came up with this:
Two conductor plug
G-R = VC to TPS and AFM
G = ?
Five conductor plug
B-R = Ign switch to Starter Solenoid/circuit opening relay/start injector
B-Bu = Ign switch to igniter/injectors/efi computer
R-G = FP power to check connector
Y-R = +B to ISV and O2 sensors
B = Tach signal to check connector
How'd I do?
