Mojave heater(finally)
Seattle, WA
Got a present for myself today. It was hard having to drill the 4 small holes for the bolts but it was worth it. I havn't wired it up yet or plumbed it into the coolant yet. I think it looks pretty good. I got it from here .
Cheapest place I found. :)
I purchased the plenum box for the front, which allows you to run a defroster hose. On the left side of the heater there is a place to clamp on a defroster hose(kinda hard to see). I will just split the hose so I can run it to both defroster guides.
Update:
I just installed my water pump today and got a chance to test out the new heater. It is a little louder than I expected but then again I can't really hear to much when I am driving around in my cruiser so who cares. It can move a lot of air and it gets pretty hot in the cruiser when it is up to operating temp. I havn't had a chance to pick up any defroster hoses yet ,to test out the defroster, but I will let you know how that works out when I get them. :D
Think this could be modified to work as a rear heater?
I am sure it could be used as a rear heater. It has to be mounted flat and takes four bolts. This heater is not just made for the front of a vehicle, it is a universal auto heater so you can decide where you want to mount it, I guess it just all comes down to how creative you want to get. :)
red66toy, Thanks for the site. I'm looking into heating/cooling options for my LV. What are the dimensions on the unit you bought. It looks smaller than the one pictured on the site.
Hmmm. Rear heaters and small units. I think I stumbled into the wrong forum....
No interest in a factory heater?
My cruiser didn't come from the factory with a heater so there is no real way to mount one. I don't have the holes in the fire wall to allow for the factory air ducting and no fresh air intake vents above the kick vent(see pick). A heater was a option back then.
Same with my LV. No provisions for heat at all. There is a dealer installed heating unit that is an older version of what you just installed. I heard it works well.
Ok, I measured the heater. The dimensions are the same as advertised. I can take more pics of it installed if you want. Also the location i mounted it makes it so you can't fully open the glove box. You can still open it a good amount, just not all the way. Also the switch that it came with fit perfectly where the original heater switch mounts.
The glove box door won't open 90 degrees? Is your limiting cable missing?
Would it be possible to plumb the intake on the heater to fresh air?
Might make a difference in the defrost mode.
Butch
Here is a pic of the glove box.
You can't plumb it to take in fresh air. It picks up air in the rear of the housing via two turbine fans with no provision for hooking up hosed for fresh air. I hope this doesn't affect the defroster setting. :)
