Matching numbers
COLLEGE STATION, TX
Is matching Serial Numbers in FJ40 a real thing? VIN(body)/Engine/Tranny
There is no transmission serial number, and the block numbers vary greatly from the VIN. For some years, you can roughly determine if the engine block was produced at the same time as the truck.
The best you can get is "period correct".
Unless your plaque has the engine S/N on it, then you can get exact (original engine or not).
Example:
1921671
Like many they didn't bother to mark a P or a V. Also besides missing a screw those are not original. I once stripped the VIN plaque from a 64 just to get the correct nuts/bolts/washers. By 9/67 they were using sheet metal screws. By 75 only using two, one on each side. Before that four with one at each corner. Not sure when in the mid sixties the plaque to from the firewall to the right side fender below the battery.
They stamped the engine serial number on the early through 1964 data plates. After that, there’s no way of knowing if the engine is original and nobody seems to care much like they do with muscle cars. You can really only go by the date code cast into the block to get a general idea of originality for anything 1965 and newer
OP didn’t state age of vehicle, hence my tongue-in-check response that early vehicles did identify the engine number on the plaque. That plaque is original to my ‘63 45, I don’t care about the screws.
