MAF Brake Conversion kit - IS IT GOOD?
Chicago, IL
Preface: please do not reply "do a search" because I have and I did not come across any reviews of the Man-a-fre front disc brake conversion kit for a FJ40.
I know there are several brake conversion kits out there - some are awful and others seem to be decent. JTO is a big no-no, but I'm looking at the Man-A-Fre kit and it looks pretty nice. Is the Man-A-Fre FRONT disc brake conversion kit a solid upgrade?
Also, while I'm there, I'm going to add a proportioning valve and I'm thinking about the master cylinder. Does anyone have a suggestion on a good P.V. and whether I should switch master cylinders?
Sure, it's probably a solid upgrade from front drums. But probably not as good as a Toyota mini/4runner/FJ60 disk brake.
You don't need drilled & slotted rotors. You can get Toyota pads anywhere, where you gonnna get the wilwood pads when you need them?
What year is your Landcruiser?
I would think any disc conversion would be an upgrade over the drums, but of course them are fighting words around here. I went from '67 single circuit, 9mm fittings to Monte Carlo calipers all around, a Man A Fre dual piston master and proportioning valve. I love it.
The Wildwood calipers look like nice stuff. Make yourself happy and do it.
If you keep the rear drums you won't (I think) use a proportioning valve in the back. You'll need a residual valve.
Pat
Oh sorry, its a 72.
Pighead - I agree it may not be as good as ones from other models, but I don't have the time/resources to do an axle swap/heavy retrofit and this seems like a good bolt on option. That's a great point on the brake pads though.. I guess I'll have to keep a couple spares handy for when I need to change them.
fireflyr- That seems like a nice set up. Not sure about a residual valve though - I thought I'd just need a proportioning valve so I get greater pressure to the front disc brakes than rear drums? Would you recommend upgrading to that master cylinder for my set up (only discs on the front)?
I don't know yet - I've requested an instruction manual but they don't say anything on the website. I think it would be silly to not install a proportioning valve though. I just don't know about the master cylinder. I guess I'll call them and see what they recommend, but I'd love any advice anyone has, especially on proportioning valves that have worked well for similar setups.
Also, there is an upgrade kit to a 6 piston caliper available too. I think that would make the FJ40 somersault! If I'm not happy with the brake power after 4 pistons, it seems like it could be an easy upgrade to the 6 should I need it.
If money is no option pull the trigger and get it done,
Any suggestion on a brake master cylinder for this setup though? I'm honestly clueless.
Suggestions on a good proportioning valve and brake master cylinder?? :beer:
I agree with pighead regarding the vented slotted rotors being a bit overkill... I have installed 3 of these wilwood disc brake conversions with great success with two minor negatives to speak of.. Performance brake pads squeak. I don't know why per say but they do. The second negative is cost. If you don't have a budget to consider than go for it (Only if you like squeaky brakes at low MPH.. LOL). The brakes work awesome! You will stop on a dime when it really counts which is ultimately what you want.
As far as the 6 pistons go I think those would only be a good option if you were planning to run really big tires (Maybe 38's or bigger), and needed the extra braking force because of the rotating mass...
On all three of my brake installations I had installed 4 wheel discs. On two of these installs I used a hydro boost brake booster with a master cylinder valved for 4 wheel discs. One the other I used a corvette brake booster with 4 wheel disc valving...
I'm a huge fan of the hydro boost brake systems. They are easy to set up and install if you already have power steering, the braking pressure or force far exceeds a vacuum boost unit (Not that vacuum boost are bad), and under complete power loss of your drive train you can expect 3-4 residual power assist braking pumps to a vacuum boosters 2 max...
If you don't plan to convert your rear brakes to disc (Not really necessary IMO) than I would suggest either a wilwood adjustable proportioning valve or buy a Disc/Drum Master cylinder (Not bad insurance) and be done with it...
Best of luck which ever way you go...
Ok awesome, thank you CI. I figure I'll never go bigger than 35s, so the 6 piston brakes would just be more overkill. I don't plan on upgrading to discs all the way around, so I'll probably just go for the proportioning valve.
On another note, I wish I had the power steering and I've contemplated adding it, but decided against it to stay more original. That does sound like a sweet braking system though.
Thank you very much again!
With the this MAF disc brake kit you will be retaining the corse spline birfields, narrow pattern drum knuckles, and the old style locking hubs, which are inferior in all ways to the newer stuff that comes stock.
You can get complete knuckle parts for a disc brake conversion from Spector Offroad. This way you get the later wide pattern knuckles, fine spline birfields, and Aisin locking hubs, along with parts (calipers, rotors, pads) that you can get in almost any parts store.
Edit:
Power steering is probably the single best upgrade you can do.
I have the MAF disc brake conversion on both the front and rear on my '72 FJ40. I have been very pleased with the results. No need for a proportioning valve. Everything works well with the stock master cylinder.
I would however, suggest that you STAY AWAY from the disc PARKING brake conversion. It simply does not hold. When I upgraded to a four speed with a split transfer case, I scrapped it out. Now I use a block of wood! :bang:
I will eventually have to change out the rear calipers for ones that have a cable parking brake. Some time later this year I guess.
Thanks fey1, it's good to hear a good sentiment on that kit. I'm going to have to get it. I think a pv would help me though since I'm only converting the front brakes. Not sure though. I've got some friends at a Toyota dealership, I'll ask one of them and see what they think.
I have the MAF conversion kits, too - excellent upgrade to the drums - works very well - the front made a HUGE difference
you do not need the proportioning valve until you do a rear disk conversion - you will need to remove the residual valve for the front circuit from the stock master cylinder, though
yes, you'll retain the coarse spline birfs - but, I have only broken one so far in 7 years of heavy wheeling use, and they are reasonably easy to come by as spares
as far as replacement Wilwood pads: you'd either have to buy them from MAF or from a speed shop - I haven't needed to replace mine in 7 years (~3000 miles/year road use) - the 6 piston calipers are the newer model brakes, probably easier to find pads for those in the long run
Ok awesome. The more I think about it, the more I think I may splurge and do the 6 piston calipers. I wouldn't be surprised if I eventually upgrade to big tires.
Did you have to get bigger wheels to accommodate the calipers?
no - bolt on
So stock 15s will fit? I just ask because the maf website had a note that they may not fit.
I suggest you call MAF and discuss with them what the issue is - I have aftermarket 15s with correct backspacing, so I assume similar to OEM - I haven't had an issue is all I can say, but your experience may vary
Got it, thank you.
