You got a 40 and now you've seen the light.
I own one third of a 62. My life is complete!!!
Complete or complicated?I own one third of a 62. My life is complete!!!
The popping out of gear issue was solved a while ago AFAIK. I've never had an issue with mine popping out of gear and I put mine in in 2006 or 2007.
Selling my ‘68 Bronco. It’s a sweet little driver. $28k. Send me a message if you’re interested and I can send a link to the FS listing I posted on the bronco site along with a gallery of pics.
FWIW, my newly installed Orion has popped out of gear twice now in 2 weeks... once in high and once in low, both times under heavy engine braking. I’ve been very unimpressed with AA over the last few months... I had to go back several times to get parts that weren’t included in the kit. We also discovered some parts that did not look like they were finished properly. And they just don’t care...
On a similar note - you all know I don't mess around much with black trails (unless @YotaFun is leading the green trail ride) but assuming this thing becomes a blue trail wheeler in the future (and maybe an occasional black) would I be happy with 46:1 gearing or will I really miss the 80ish:1 ratio the Orion would provide?
In a perfect world, 3.7 diffs, a H41, and an Orion would net me about 70:1 and probably be an almost perfect combination of streetable and trailable.
I did some math. I know omg!On a similar note - you all know I don't mess around much with black trails (unless @YotaFun is leading the green trail ride) but assuming this thing becomes a blue trail wheeler in the future (and maybe an occasional black) would I be happy with 46:1 gearing or will I really miss the 80ish:1 ratio the Orion would provide?
For reference on my 4runner with axle gears 5.29's, crawl box 2.28, t case 4.77 and a 1st gear of 3.83
High is 20:1
2.28 low 46:1
4.77 low is 96:1
Low low is 220:1
That 4.7 low @ 96:1 is my go to ratio for most moderately technical areas. I use this on blue trails alot, hill climbs and rock crawling as well as hill decents.
46:1 is only good for green trails. I have to become a throttle jockey if I need to use this on blue trails. Blacks don't try it's just too fast.
The question is, if I dump $600 into a 3speed case rebuild, for 46:1
Are you sure you already do not have a 3spd case?
They were oe till april ish of 75.
OBTW, the three speed cases are more brittle and can split (ask me how I know).
forum.ih8mud.com
I'd like to know the details of the "output shaft being out of tolerance". Gears loose on the output shaft? Too much difference between the gear(bushing) ID and shaft OD? To me more likely too much end play on the gears and could very well indeed lend itself to a popping out of gear problem. The side to side clearances on the output shaft gears need to be checked and adjusted properly to keep everything kosher.@Stumpalama - over in the 40 forum Orion sticky there’s a guy who was saying the output shaft was out of tolerance (all new parts). It was too loose. He caught it during assembly and sent it back to AA, hasn’t gotten it fixed yet because they’re operations are limited by Covid. Gears loose on the output shaft could certainly cause them to pop out of gear, I suspect.
