from flexalite:
How far should I put my fan into the shroud opening ?As close to half in and half out as possible.
I think the ringed fan was a pathetic attempt at that goal.
While I understand what you are doing I think the factory probably adheared to those specs on the initial design
Now we' re at a point where we are modifying that intial design and certain compromizes are made in lieu of completely redesigning the system
The idea is to minimize those modyfications so as to maintain as much of the original performance as possible .
With an OEM three row brass radiator I have roughly 1 7/16 inches from the blades to the core. and a couple credit card thicknesses between the back edge of the blades and the blower belt tensioner pulley.
to your point though Rick, don't you think we are basically at this point using a custom setup? so general rules applicable to custom shrouds and fans should apply? not trying to be argumentative just trying to learn and assess how the unit will fit.
that doesn't appear to be a stock radiator!
I didn't take any pics but it looked to me that the back of the fan blades were outside the shroud by a half inch. Orange hub, stock fan and Koyo aluminum rad
my 3FE fan on the LX sticks out a bit more from the shroud than Guppie's - I suspect your radiator is a tad thicker than stock
thx Rick, since I don't have a stock 80 to look at, does the stock 80 fan sit close to the stock shroud (tip to shroud)? I have over a 2 inch gap there, seems that here is where your clutch will help alot. Just curious how close the stock fan is to the shroud as it rotates.
this is the ID of the shroud to the OD of the fan, correct?
thx for this, if you have pics I would really appreciate it! that would give me a guage of if I should and how much to cut my stock fan shroud.
