You should really read through the FSM as there is a lot more to it than just setting that torque. However, to specifically answer your question, here is a cut and paste from the FSM:
Simple answer is yes... Get a chunk of angle iron around 2"X1/4"X3' and drill two holes that line up with two holes on your drive flange (you'll probably need to grind out a spot to get the pinion nut socket on) then let the angle iron rest on somethin solid like the ground or frame while you torque the pinion nut.i'm just curious if anyone that is smarter than me has figured out a way to torque the pinion properly (with old bearings and shims) with the diff in the axle with shafts and tires attached.
That’s just the stuff in the kitchen ‘catch-all’ drawer that was robbed out of the night-stand.I’m not as sloppy as Jmack though w my 10mils. You can also tell by his finished work, as well.
If the impeller was broken it could cause the bearing to go out on vibration, which again would likely cause it to leak out the weep-hole.No need for a temp gun. I can feel the intense heat when I park it. Way hotter than all other engines I have. It steams/bubbles out of the overflow bottle for 10 minutes once I cut it off. Radiator is clean inside and out. Clean 50/50 water coolant mix. Fan and shroud are intact. No thermostat. It will sit and idle for days and not overheat. No air flow blocks in front of the grill.
If the water pump impeller was broken internally, that would kill the pump bearing right? Or make some noise? Water pump spins fine and doesn't leak.
My 78 40 was exactly like that! Never found the problem. I could drive for 2 hours at highway speeds and when I stopped it started pissing and moning and girgling. T stat no, water pump NO, cooling flush NO, Air trapped NO! I always flushed my coolant through the block so NO entrapped air! So just took T -stat out in Summer and put back in winter. Oh and used stainless hardware to ease the Seasonal changeWill check all that and report back 100%, however I've driven this thing for 15 years and no issues. One failed water pump that I replaced 5? Years ago along with factory shaped coolant hoses.
Its been fine, around town and highway since 2011. Same rad, cap, hoses, thermostat ,and always clean coolant. I drive it maybe 200 miles a year. And only work on it very occasionally.
Then 2 years ago it started to run hot kinda out of nowhere, so I removed the thermostat to rule that out. No change. Still hot. It does not leak coolant anywhere while running and coolant is topped off.
Diving in !
head gasket
