just bought an aussie
sittin on the couch in UT
just bought an aussie locker tonight, any hints or what i would have dones from those guys that have installed them before. im thinking its not rocket science but would like to know if i should replace things while im at it? thanks :)
When i put mine in the front i thought i missed something becaue it was so easy. It takes longer to get the diff out than it does to put the locker in.
yep install is a piece of cake, just make sure you have the right spacing/gap in the locker or you will shear off the pins in no time............
the instructions will show all that wont they, and should i get new stock shims or washer and some axle seals? thanks guys
The last step is measuring the gaps with your feeler guages - if it's in the front you can't check it as easy as you can keep an eye on the rear. You have around .030" range, mine was a little out of "ideal" but I'm not sure how critical it is to keep it towards the closest end of the specs. Can't hurt though I suppose.
The instructions kind of skip around a bit - they are generic for all applications but it is super easy once you see the thing and have the pieces in your hands, Romer's pics are great and there isn't much too it once you get started. A little luck and lots of grease and you should be fine.
Dont forget to get the seal for the diff cover and diff fluid.
Get a yellow hi-lighter and go through the instructions hilighting the parts that pertain to your install. It helps cut through the BS and stuff that you don't need. I've found this a useful practice with most all aftermarket instruction sheets.
I just finished putting mine in 2 days ago. I went ahead and ordered new thrust washers because I was already in the upper threshold of the range and I thougth it would be best to be in the lower threshold. Very easy install, the only thing that took me time was measuring because I wanted to make sure I had it just right. One tip that may not be spelled out in the instructions is when you're putting the cam gears in (pieces w/ the hole cut for the BIG pin) slide the small pins all the way into the cut out hole then once the cam gears are in the diff you can slide them back into their receiving end and install springs.
oh yeah.. go ahead and replace the axle seals while you've got the c clips out... If your cruiser is like mine, all the rubber seals are starting to fail and I don't want to have to get into my diff again for a while. Not even sure how to get the springs out of the locker now that they're in there. :doh:
just ordered axle seals and some new c clips and gasket, the guy at specter said i dont need new thrust washers and the kit comes with some? oh yeah i tracked my locker and itll be here on monday. yeaahh
guess ill be calling kurt and running up to sandy
Bought an Aussie (locker.)
Hi All:
For LockRites, and their clones (EZLocker, Aussie locker, etc.) be sure that both tires on the driven axle have exactly the same tire pressure. And, use a heavy gear oil, such as 80W140 weight to help dampen the locker's mechanism.
HTH.
Regards,
Alan
Seattle
