- Thread starter
- #21
See post #16 for my LED reasonings. Here's the list:
This list should work for 1975+ 40's. I compiled it using Trollhole's list as a starting reference. Please let me know if you find any errors.
www.superbrightleds.com
headlight switch
1x- BA7S-W Cool White
parking
2x- 67-W15 Cool White
rear side marker
2x- 67-R15 Red
front & rear turn signal
4x- 1156-A45-T Amber
tail/brake 2-way
2x- 1157-R18-T Red
reverse
2x- 67-CW2W Cool White
dashboard & heater control
2x- 3022-WWHP4 Warm White (some people buy green)EDIT:
I don't think these are correct. I haven't installed them yet but they appear to be the wrong style. Will update when I can.
front side marker
2x- 67-A2W Amber
interior dome
1x- 3710-WWHP6 Warm White
turn signal indicator
2x- WLED-G-120 Green (I like these but -G-90 will be brighter)
hi beam indicator
1x- WLED-B6 Blue
flasher
1x- CF12ANL-01 (you'll need to make 2 simple adapter wires)
I left off the Gauge Cluster bulbs because I don't need them. Many people say that brighter bulbs won't help in the cluster unless you break off the tabs that surround the bulbs. I also hear that just removing the tabs and keeping the original bulbs works well. Some folks have used the hi-powered incandescents from CCOT or others and reported fogging and condensation problems because the bulbs get so hot. I'm swapping in a gauge kit that uses a mini LED rope light to replace all the cluster bulbs.
headlight switch
parking
rear side marker
2x- 67-R15 Red
tail/brake 2-way
2x- 1157-R18-T Red
reverse
I don't think these are correct. I haven't installed them yet but they appear to be the wrong style. Will update when I can.front side marker
2x- 67-A2W Amber
interior dome
hi beam indicator
1x- WLED-B6 Blue
flasher
That was probably the largest upside by far.
