Instrument cluster lights
Carlstadt New Jersey
I just removed the dash cluster and install (5) led panel illumination lights. After installing I have no lights. Idiot lights and drive/park lights seem to work and the dimmer for the drive/park and ac panel. If I'm not mistaking, these lights are run off the tail fuse which I checked and was not blown. Any other ideas before poking around with test light?
Thanks
LEDs are polarity specific. Try rotating one 180 degrees. If it starts working, do the same on the others.
The odds of you getting 5 backwards is not great, but possible.
Is it possible if a couple were in backwards that it could stop power from going to the remaining?
I must have hit the jackpot and had 4 out of 4 Leds installed in the bayonets with the wrong polarity. I removed the cluster for the 3 time, marked the negative side of the bulbs, and reinstalled. All is good now.
Lol, I tested my LEDs with a power supply and marked the polarity on them before installing. It's not to hard to locate the common negative rail for most of the panel lights.
What colour LEDs did you use. I went green for illumination.
Changed all the other lamps to LEDs of appropriate colours EXCEPT the alternator charge light.
If you try to LED this one it mucks up a few of the others and makes them glow ever so slightly which is annoying.
Anyone have photos they could post up of the instrument cluster with LED's (on) at night?
I went with the white for the (4) main bulbs. I left all the others stock bulbs. I did a test run last night and had no problems with glare from the new LED's.
There are a few pics if you search up Instrument cluster LED's. Removing the cluster is a bit of a pain in the ass to disconnect the plugs and weasel it out from around the steering column. There was actually a pretty descript step by step thread someone posted on the removal if you search under (cleaning instrument glass) So if your going in, I would suggest doing the bulbs in the gear selector lights while your in there. Make sure you test the bulbs for polarity and mark them when you install the in the factory bayonets. the bayonets can be ambidextrous so you need to take notice when installing them. Like Sarmajor posted above, if you look close, you can follow the foil tape and notice that they will be either marked in gold print with (-) symbol or with your manual all go back to pin (1) on the female side of the plugs. So when installing the bayonets, make sure your ground side you marked the bulb/bayonet is on the ground side of the foil ciriut board.
I just ordered a new to me cluster from jason over at cruiser yard. My tach has been dead and now my speedo is sticking.
Ordered 4 amber LEDs from superbright LEDs... Wanted to match my ham radios display color, I'm excited to see how it turns out.
I have messed with these 3X. Dash lights flicker, which will drive you nuts and they go out periodically.
Not just a plug and go like the others in the truck.
Make sure you replace the Indicator Wheat Bulbs (P, R, N, D...)as well while you have it apart. Takes an extra 5 mins.
When I put in new turn signals (all 4 Orange) the turn signal dash indicators would come on when you hit the brakes.
I used the Superbright LEDs flasher instead of a resistor so they run at very low amps.
Ripping out the trailer harness in back by where woofer and amp sat fixed that.
Just ordered up the Curt 56156 (Made in USA!) to resolve that issues was $23 shipped for free
Yea I'm not interested in converting the indicator bulbs or the transmission indicators. Hopefully that keeps the brain damage to a minimum.
