Hydro Assist Threads
Here in Iceland, all modified 80's and.. I guess most of all modified 4x4 that have been put on bigger tires, 44" and bigger have hydro assist , My 80 has one mounted on the drag link , behind the housing , mine has 44" tires. My friends has his on the front , his housing is a modified one, LC60 third and with the stearing arms at the front , he's running 46" tires
Hydro assist has 2 purposes for us, being able to turn those big tires on those wide wheels, i've got 18" wide wheels on mine, also to stabilize to get less death wobble , being towed withouth power steering is not something that I want to do :)
Yes I noticed it minimized my DW.
Have any pics or sources for parts? Are you using the 1.5 x 8 ram?
Thanks,
Do you have a hand throttle installed? Simple way to increase your minimum idle speed when you need to, and factory fit to boot.
No I don't. But that's a great idea. How hard are they to install and cost?
Is there a reason why you guys aren't moving the tie rod to the front? Seems like a pretty simple job with a RHD arm. I'm working on a Y-link steering setup. Have all the parts, just need to get the arms reamed out. That would make hydro assist much easier IMO.
Me personally I don't see any point doing so. It will not get me down the trail any farther. My front is solid and reliable. And I don't want my tie rod up front to get bashed in. And the way I wheel it will.
Adding hydro to the stock set up was cake. It's like it was designed to go there. It works mint.
I bought mine here on mud, I think it was Akella? Selling them. It was about $50 and takes about 5 minutes to install. All the factory parts it attaches to are already there.
Thank you! Will check into it.
Double check on that hand throttle. If your 80 is a 91-92 and a good deal of 93-94's you will not have the correct gas pedal to attach the hand throttle. I know from experience.
I agree with leaving the steering the way it is and adding the ram to the tie rod. Keeps it simple.
Mines a 96.So I'm GTG.
Jits, what is the bore of the Ram you are using?
I assume these were all purpose made, (I built my own) but if anyone has them made already, I would guess Ruffstuff.
I know older thread.... but any idea where you got that mount for your axle?? Im getting close to getting this done! Im just needing a couple small pieces now
Might be able to make these work: https://www.trail-gear.com/TG/Hydro...ing/i_0_0_462/_130254-1-KIT.aspx#.V357RvkrJhE
Might take a bit of massaging with the grinder but it beats building them from scratch. I had to modify the bracket on the axle housing to fit against my diff
I got the mount off Ebay and is designed for an Dana 60. It works perfect.
