That key falling inside the block was my biggest fear. I ALWAYS move the crank to the top, 0 deg, just a habit from changing timing belts. The key is at about 8 O'clock viewing from the front. When I placed the crank pulley back on, I had markers on the block where the key was and also markers on the pulley where the key guide was. I wiggled it in very slowly. It was the second most tense moment in the seal replacement.
The oil pump screws were my first fear, in case they would snap. I hammered in the bit #3 and used a torque bar to gauge the force. They all snapped loose around 14 lb/ft. I did replace them all just in case. And I did put a small coat of Toyota RTV sealant on the oil pump cover.
Side note: When replaced the distributor seal. I marked with a Sharpie where the distributor should line up with the block, but I forgot to notice where the rotor was before pulling it out. Good that the rotor has a mark showing where it should be before inserting and also good that I put the pulley on the top center before pulling it out.
I now must have the only FJZ-80 out there running Mobil 1 with NO leaks.
(though not for long).
