OK.
I'm 75% ready to say that I was wrong, but I still have a couple issues.
I WOULD appreciate it if you could find the time to help me get past my remaining questions, above.
Hayes
I actually think Heath now has a grasp of this completely.
Hayes, where I see you having some difficulty is in how the VC works. Think of it this way, 1 set of plates is attached to one axle, the other set of plates to the other axle. When there is slippage, the axles couple together allowing TRANSFER of torque from the slipping axle to the non slipping one. No speed differential between axles = open diff.
Hayes, for your presentation to be true, one side of the VC is attached to one axle, and the other must be attached to the housing of the transfer case. Now you can have the VC absorb the energy of that axle, raising total supported torque. But the VC isn't attached to the housing; as your drawing shows, it's attached to the other axle. So the VC only needs enough energy to lock up (read: very little, since it is *only* speed differential that locks up the VC), then torque will transfer to the opposing axle.
In EDL, the brake is attached to the chassis of the car (like if a VC was attached to the transfer case housing), it's not TRANSFERING torque, it's absorbing torque of the slipping axle. This raises total supported torque of both axles thru the center diff.
I apologize for presentation, I get that way over what are IMO basics of AWD operation. I normally nerd heavily in the Torsen Center Differential applications and chassis dynamics, where a lot of variables affect torque allocation.
That said, always good to go back to the basics of LSD's and lockers once in a while.
HTH
ST
