How Center Diffs Work
Comments:
Mace - Happy to take to Private Messages any confusion you have regarding lock/couple vs unlock/uncouple. A lot of views on this topic. Getting mired a bit by your insistence. I will make the offer to change every post to couple/uncouple if you then delete your challenges to do so. My understanding of how the VC works hasn't changed since Post 1. I know others understanding has. I'm good with that.
WE - I believe you are trying to read too much into what I say. I congrat you on the ability to take my nerdy posts and give it up to the masses. I'm almost sure you now understand how a VC works. FYI II, the vw synchro per VWOA refers to the vanagon synchro with a VC. The audi 'synchro wagon' has the gen 1 locker system, and is referred to as the passat everywhere but the US, and in the US parts fiche as well. When I refer to SYNCHRO, I refer to the vanagon with the VC, not the QUATTRO in the audi synchro wagon. HTH
Hayes - I don't have any disagreement with your statements since we got you to connect the VC to the other axle. Regarding the TBR, think of what happens when you try to apply more torque than the total supported at the maximum TBR. Lowest supported torque axle will spin again. Hence in my example of 50lb ft of supported axle torque front (traction), 4:1 TBR = 200lb/ft rear supported torque, total supported torque to both axles = 250. At 251 front axle will spin. Thus enters the realm of drive by wire throttle control programming in TCS. A lot of work on this with torsen applications. Help?
LT - I agree that heat is a necessary component to (er) 'coupling', but be careful regarding it's ability to uncouple. The design of the perforations in the plates dictate that can be very fast regardless of heat. For ABS, remember if you take your foot off the gas, axle speed differentiation will decrease to 0 quickly.
I hope folks find the thread useful in undrestanding how diffs work. The usual :popcorn: hopefully just made a nerdy subject more entertaining!
:cheers:
ST
Comments:
ST
I'm good with that..
Mace,
One of my driveline buddies puts forth this thought for you... The reason one uses locked/unlocked in a VLSD is that a Viscous Limited Slip Differential can never "uncouple" because in the 'uncoupled' state, the 2 axles are mechanically attached to support 50/50 engine torque. It is more appropriately a 80% locker, or it's unlocking the center diff to be an open diff....
A VC with no center diff can "uncouple" because the uncoupled driveshaft is no longer attached to the other, and torque can be sent to one axle and not the other.
I reread all my posts since post 1. I see no reason for confusion, and certainly some exception to your 'uncoupled' driveshaft referring to a VLSD center diff application. Uncoupled, it's very much mechanically attached.
Me, I'm good with how I described the VLSD locked and unlocked operation in every single post in this thread.
ST
Comments:
:cheers:
ST
ST
Of course, now that I've picked myself up off of my seat from surprise to see that you are actually willing to compromise, I see that on the second thought, yer not! I should have seen that coming! :doh: :doh: :doh:
Talk about "insistence"! :D :flipoff2: :D
Mace,
ST
lol
Question, does a VC create a 1:1 direct drive to the front axle? (meaning no slip at all..)
Or better, what do you consider the definition of "locked"
WE I'm almost sure you now understand how a VC works.
ST
Your never gonna change are you dude?
Its statements like the above that don't win you any friends nor influence anyone here. Maybe this fly's in audi land but your tone as usual is condescending and 'always right'. Maybe you should push back from the keyboard and go rest your arm. Its gotta be sore from how hard you seem to be slapping yourself on the back. Want to talk some more about frame geometry?
