What happens if you drive around with the CDL engaged on dry pavement, LandTank? How soon will "it" happen...and will it happen every time?
Who cares? ST recommends it!
Well it's a bogus riddle for a few reasons:
1. VC's don't lock, they couple. Locking would indicate a solid connection. It's also why it's called a viscous coupler, not a viscous locker. I know you're a stickler for terminology.
Not part of the riddle.2. I'm on dry pavement, the VC isn't going to be coupled anyway cause I'm in a 80 series and there is no way I have enough horsepower to get one driveshaft to spin faster than the other in a straight line.
3. If you read the part of the SAE paper I linked that is readable, you'll see that the turning radius speed differentiation is not enough to effect the VC.
Please explain this without formulas.
VC's lock the axles when they couple. 80% locked actually. This is how one refers to a VC that carries speed differentiation. The VC LOCKS over the center diff at a 4:1 TBR. Since it can hump, it can also FULLY LOCK. Heath, if the VC can FULLY LOCK, and the same VC can PARTIALLY LOCK, it locks to axles together over the center diff?
Because the coupled axles aren't *locked*. Locked the axles can transfer 100% of torque to the other axle. Viscous Coupled, neither axle can support 100% of Trg, nor can you transfer 100% of torque to the other axle. Both axles can support a % of the other, ascribed by the SAE boys by TBR.
talk slooowly and simply for a poor old engineer please.
OK, I am going to throw a spanner in the works. Couple of years ago I was on Golden Spike and tried to climb Double Wammy. Forgot to lock the center diff in low range (dam pin 7 mod). The truck would climb halfway start spinning tires and then the VC would let go and you would slip back down the obstacle. There was no tire lifting. Just all 4 tires spinning until the smoke rolled.
I always thought about the VC as being on most of the time, but if the forces (whatever they be) is to big it shears and lets go. Please explain this without formulas.
This coupled with 80's that are on the rack. When you try to turn the front and rear drive shafts in opposing direction it is really tough with the VC in the transfer case. Without one it is easy.
ST
That's an easy one Christo. Remember, the VC locks up only if the axle speeds are different. "4 smoking tires" sounds to me like the axle speeds are the same = no VC locked up. Remember, the VC is dumb, it is only reacts to driveshaft speed differential. This will happen a lot in a straight line (i.e. hill climb event or ice/snow driving) Once the VC has equal driveshaft speed, it's not coupled anymore. NO MATTER HOW MUCH TORQUE IS APPLIED. It's a axle *speed differential* LSD, not a TORQUE LSD.
Again, this is because the VC is NOT A TORQUE DEVICE. It's a speed device, so you turn the driveshafts in opposite directions, the VC will lock up due to speed differential. Hand 'torque' is enough to lock up the VC.
Last year at steamboat ice track, I rarely had the VC locked up when I ran open diff. That's because as soon as it locked, the rear wheels spun, and the VC unlocked.
ST
I also would like someone to summarize this discussion without the complicated formulas, acrnyms or detailed tech speak. My EE degree isn't helping me here and I don't want to pull out my old engineering books to understand.
So you are saying it was not locked up when I started and then locked up due to driveshaft speed differences? In that case I should have been able to climb the obstacle just like with a locked center. Sorry, that just does not make sense. I can not believe climbing that obstacle that I had it perfect and both axles were spinning at the same speed.
Sumo, there is a funny thing about so many people telling you that you are not explaining things well.
They typically are not wrong
And..
How can something be "locked" if it slips..
You pride yourself in being technically correct then make incredibly misleading statements.
Lock = complete and unchallenged control; an unbreakable hold..
Would you call a limited slip posi a "locker"??
ST
