Why I usually present center LSD as a rubber band type concept. You stretch the band out from it's static state to help equalize torque load, once done the rubber band wants to return to it's static state. That's thru a reduction in TBR back to it's static state unless some other force interferes with that return (like turning radius). Hence, my riddle to WE.
HTH
ST
I realize I'm chasing my own rabbit here, but I think in the end it's related to the % locked debate.
I think your half a step away from where my conflict is, or I'm half a step away from understanding your explanation.
Following the rubber band analogy, the force the rubber band exerts (analogous to the quantity of torque transferred through the VC) depends on how far the rubber band is stretched (the magnitude of the speed differential), no?
Say you have Arnold Schwarzenegger (really strong, analogous to lots of torque supported on the axle) stretching the rubber band 5 inches, and then you have Michael Jackson (supports very little torque, in addition to several other problems) stretch the rubber band 5 inches.
In both cases, the rubber band is stretched the same amount (same speed differential), and the same force is exerted (same amount of torque transferred).
When you say that the VC transfers an amount of torque that is a
percentage of the torque supported by the spinning axle, in the above analogy, the rubber band would be exerting more force for Arnold and less for Micheal--even though they both stretched it the same amount.
Apologies for mentioning Michael Jackson in this thread.
In my mind, the VC is like a rubber band or spring where the spring constant and the length of stretch define the force (F=kx).
If I generate a speed differential of x, the torque transferred by the VC is always F, regardless of the torque supported by either axle.
The VC reacts to speed differentials, not torque.
