I will attempt to knurl the ends but really do not think hardening is required if a high-strength steel is used for the pin.
Are you planning on just doing a set for yourself or providing a service?
wanted to avoid reaming out the hinge-pin hole to fit a larger bushing/pin but cant say I am totally opposed to it
It’s been a bit since I redid my hinges but I believe if you don’t oversize your bushings the wall thickness is unreasonably thin for the bronze/brass material.
I think I donated all my extra hinges to you. I’ve got another pig I need hinges rebuilt on. I’ll send you those to do and any other I might have. $80/ pair so $320 all 4 doors?I still have a box of hinges donated by one of you. Send your broken and worn out hinges this way whether you want them rebuilt or not. I will use them as free parts for all until they are gone. Send ones over for rebuild too. $80 per pair includes return freight.
I was thinking the same thing when I looked at that photo. It really doesn't "look" bad but it feels like alligator skin when you spin it in-between your fingers. I am pretty confident it would chew up brass or copper pretty quickly given how soft that material is. Also would like to NOT have to revisit it again anytime soon. I think the NAPA kit is going to work out well although I wish the knurling at the top went a bit higher so I wouldn't have to leave any kind of shoulder on the pin.Thinking about that corrosion on the pins, yours doesn't look bad where the pin rides in the bushing. Do you still think it would eat up the bushing? Very cool jig, that will make it a lot easier rebuilding them. Waiting to see how the knurling tool works.
Let me know and thanks again..
Pat
Just received mine from Midgainc and man are they NICE!! Very good work and thanks much...
