Hamom for father of soldier killed in Iraq- Part Un
OK - thanks. So the H42 that is on the current 2F or the 1F is what we are going with?
Won't we still need to switch out the bell housing for a 40 bell housing? And what kind of tcase do we need?
We will use the H42 that is in the garage along with the T-case that is attached to it. They also have the bell housing.
Hey guys, onea the Chatter's brought ya to the forefront: linky https://forum.ih8mud.com/chit-chat-section/342299-soldier-cruiserhead.html#post5059591
Any chance you can give us a synopsis on what's needed, so the greater Mud community can chip in?
Not trying to crash your party; just wanna help a Mudder, if you'll let us.
ps: this post reflects my opinions only, blah blah blah, gov.speak/lawyertalk: *** 'em all... We're here to help a Mudder...
even if it's just me.... :o
i've got one as well as a throwout hub - i can mail that during christmas break.
Awesome. If you don't have my address please shoot me a PM and I'll give it to ya.
I don't think he meant anything by it.
I can make his windshield and hood hinges look like Bsevens in this picture. I hope you dont mind me using your pic Bsevens my camera is busted. If you guys want to ship them to me, I will do the work and ship them back on my dime. Let me know, shoot me a pm.
https://forum.ih8mud.com/40-55-series-tech/176657-sourcing-windshield-hinge-pins-bushings.html
Brian
That would be awesome! I emailed the father and will talk to him tomorrow about pulling the windshield hinges and door hinges and ship them to ya - stay in touch.
And to everyone - if you PM or email me and I don't get back to you ASAP please hound me - I'm just swamped and WILL get back to you.
Thanks everyone for your help!
*Front axle rebuild kit - only need (we think) 1 hub seal and 1 inner axle seal, and new bearings
*driver's front shock mount
*Stock rear brake lights,
*Stock rear bumper
*1 rear wheel stud
*3 speed tcase, current one cracked
*Fuel filter
*Heater defrost knobs
Steering wheel
Spare tire carrier
i just saw a link to this thread posted in the wanted section by rob aka landcrusher909. this story is beyond sad and i'll be more than happy to help with the parts listed above if they're still needed. please contact me via pm or email with the list ( still needed ) and the addy to ship the parts to.
most sincerely; my heart and thoughts go out to the family.
georg @ valley hybrids :frown:
Might have found some Long Jump seat frames I will keep you update
As Forest Gump said, "That's good, one less thing!" As long as they are not rusted through and the hinges work, we are in business.. Thanks!
JP has emailed saying his front seat from a late 60s early 70s is available. Since we have some good vibrations from the left coast, do you guys know if that bench will fit a '72? (We aren't worried about the charcoal cannister in the seat, I think . . . .)
Thank you so much Georg. I think we need all of those except the 3 speed t-case!
You can ship the parts to me.
Steve Springs
203 Grayson Dr
Travelers Rest SC 29690
I'll send you a PM too.
Thanks again!
Steve
WHAT WE CURRENTLY NEED
Monetary donations
Parts donations Have
People Will be there Saturday and Sunday
Publicity
Sponsors
Work tables
Work chairs
Canopies
Lights Have a few 500w light stands that I can bring may need bulbs
Tools
Floor jacks Have a few
Jack stands Have a few
Shop towels
Air compressors Will bring small air compressor and air tools
PARTS WE NEED
* = first priority
*POR15, RustBullet, or Rustoleum paint for frame
*Rear tailgate handle for 1972 FJ40 I have
*2f parts - gaskets (oil pan, side cover, rear main, front main, front cover, valve cover), all new belts, motor mounts (rubber square pucks)
*tailgate hardware - I Have
*Stock rear brake lights, reverse lights (all)
*Stock rear bumper Not eactly sure what this means.
*1 rear wheel stud I think there were more than just one I'd say 5 just in case.
*Stock seats (front and rear)
Power steering
*Battery tray and hold down
*Rear brake rebuild kit including pads
*4 speed T-case rebuild kit
*new radiator hoses, radiator looks OK
*new heater hoses 20ft of 5/8 heater hose
*High temp header paint
*Brake master
*Clutch slave spring
*Radiator overflow bottle
*Fuel filter
*Cowl vent seal
*Cowl vent drain tubes
*Hi/Low switch on floor Highbeam switch
*1 right/passenger windshield washer arm Have one
*Stock rollbar and bracing
*Defrost vent hoses
*Complete fuel line (soft) for whole system (5/16") 20ft needed
*Gas tank liner kit
*Spray in bedliner
*Parking brake rebuild kit
*Lugnuts for aluminum rims
*Rear sill body mounts
Tcase shifter boot
Turn light lever on column
Steering wheel
replacement rear sill And sill cover
~3" lift (leafs, shocks, shackles, spring bushings, all of it)
headliner
Dash pad or Dash pad cover
Front disc axle
Centerarm rebuild kit
Headers
2 door limiters
Door felts, seals, gaskets
2 sunvisors
Steering column seal
Seal between fiberglass top and metal sides
Spare tire carrier
Tailgate seal
Rear emblems
PARTS ALREADY DONATED OR SOURCED
Brand new carb and dizzy thanks to Trollhole Cruisers and Two Springs Consulting
Gasket kit courtesy of apeterson and Two Springs Consulting
Running boards courtesy of apeterson
Labor to pull 2F out of donor vehicle by ACC Toyota
Much more hopefully to come...
WHO I NEED TO GET BACK TO ABOUT PARTS, ETC
ACC - special tools needed for build, if 2F needs anything
jsaltlick - parts needed
raYGunn - PayPal
We need to line up a large air compressor. Maybe rent one from a local rental company.
I have noted in red what I will bring as well as some other things that needed to be clarified.
Also do we need a clutch? Plus we need to give ACC some money to turn the flywheel down for us. Probably just get by with a new clutch disk, throwout bearing and pilot bearing. I'm sure the pressureplate is still good. ACC should be able to tell us.
Also the dizzy off the 60 would be better than the one I have.
Steve or David,
Sorry this is the first time I have even looked into the thread and I tried to skim thru it is quickly as I can....... I still have the bench seat and I believe a 3spd t/case if these items are still needed. You guys can shoot me a PM if you'd like.
Regardless looks like you guys are putting something special together and it kills me that I have to be out of town that weekend, but I will gladly donate what ever parts I have that ya'll need to make this happen.
:cheers:
JP
*edit * I also should have the headliner material and sunvisors although I will have to check on the condition of the visors.....
Steve or David,
:cheers:
JP
JP - sounds awesome about the visors and headliner material. Please check on those for us.
I think we are good on the t-case though.
BTW - your old 62 is up for sale! Want it back? :grinpimp:
I know you guys are also looking for a factory roll bar and are planning on using the long style jump seats...... I could be wrong about this but I believe you can not use the long style jump seats with a factory roll bar with out modifying the jump seats frames. That is why Toyota switched to the short style jump seats when they started installing rollbars.
With all that said I have an aftermarket roll bar out of my 1962 FJ40 that should work with the long style jump seats and I would be more than happy to donate that as well......
JP
Hello All,
I apologize for not posting sooner. As I read the progress of this HAMOM, I'm amazed and speechless. Each day I am touched by the response of the members of this forum and those who may not be members but have heard of this project. When Steve contacted me with the idea of Upstate Cruisers, other clubs, and the members this forum helping out, it never crossed my mind that the response would be this great. Two years ago when I first posted Josh's story I thought I could learn how to work on Josh's FJ and eventually get it running. I never dreamed that so much could happen in such a short amount of time. All Jean and I can do for now is say, Thank you. I look forward to meeting those that come down next month. If I can do anything for ya'll please let me know.
Here is the flight plan for my arrival
Thursday, January 14, 2010
US Airways # 349
Ontario International (ONT) to Phoenix Sky Harbor Intl (PHX)
Departure (ONT): January 14, 10:00 AM PST (morning)
Arrival (PHX): January 14, 12:12 PM MST (afternoon)
Class: Economy Your flight is confirmed. The airline is assigning seats at check-in choose seats
| PHX
US Airways # 612
Phoenix Sky Harbor Intl (PHX) to Atlanta Hartsfield-Jackson ATL (ATL)
Departure (PHX): January 14, 1:04 PM MST (afternoon)
Arrival (ATL): January 14, 6:36 PM EST (evening)
I will be leaving Sunday in the afternoon. We are gathering steam out here and are getting together what we can, A Few things I need to know Orange 45 has offered to donate tranny and t/case gaskets, what year and model trans are we working with ? this will help in finding the right E-Brake kit This weekend i will be putting together a list of what We have I am still working on the jump seats. Steve its been great talking to you and cant wait to meet you all,​
Update on a Gen-u-Ine '72 Front Seat
Looks like we have a "three-way" (deal) going on a genuine 72 split front seat in good condition. It involves 2 folks from Salt Lake City, one from Charleston, and me in Asheville, acting as sort of a Jay Leno. ATTENTION LOW COUNTRY CRUISERS: your assistance may be needed.
Click on this link to join in the fun: https://forum.ih8mud.com/sale-parts/340168-72-fj40-front-seats.html
