never measure mine .. but I indeed have to move cross member forward .. manual H150 ( in mi case ) it's definitely shorter than my A442F and therefore you must adjust your DS front and rear ..
Can anyone verify the 70mm movement forward for the cross member new position for H151 with 1FZ-FE engine? I see you guys doing that with the H151 and diesels, but not sure if both engines will put the transmission mount in the same place. I see the forward holes in the frame for the adjusted position, just wanna be sure these are for gas engined 80 also. give me a reference measurement?
Thanks,
Joel
Well, finally got my grubby hands on an H151 along with some extra parts! ....
Any of you swap guys have a successful method for wiring in the reverse lights to the manual transmission reverse switch? I've got some ideas of what to try, just wanted to see what others have done.
