IMHO all 06-up, all makes and models. Need action taken w/S.A.I. or they kill the CATs and more.
I have actually fully disabled that system, fortunately. I've read your theories and diagnoses of that issue! Always appreciated
05 173kWhat year and miles?
I'll guess 06-07 150k to 250K miles!
I've been getting the P0420 and P0430 codes for a while now, and have been resetting them via the Torque app. On Saturday, I finally got around to running a bottle of cat-a-clean through it, and then this morning the dash lights up and I'm getting P0420 and P0430 again. The dash typically lights up 1-2x per day, so the 3 days I got out of it was longer than usual. Should I run some more cat-a-clean through it? Check the O2 sensors? Would really hate to have to spring for new cats.
You can try 2 cans 44k in full tank. Sea-foam foger. Than Chevron techron, next tank. Yes even more CAT-a-clean (last best IMHO).05 173k
I can’t thank you enough for this. Honestly, so much of this is over my head. If it’s alright with you, I’ll shoot you a DM to see what my options are. If you can fit me in, I’d be happy to become one of your customers.You can try 2 cans 44k in full tank. Sea-foam foger. Than Chevron techron, next tank. Yes even more CAT-a-clean (last best IMHO).
But very unusual for a CAT, even more so for both to go bad on 98-05 even at 1 million miles. You must find and correct upstream issue first. Or you'll keep killing CATS.
Once I'm sure no excessive fuel or oil being dumped into CAT. I do a high RPM run on HWY. About 4,500 RPM at ~60 MPH, gets CAT temps to max. But if suspect fuel or oil, built up in CAT. I use cleaners first. Since they CAT with "fuels", can ignite and burn up.
Watching fuel trims and ECT can yield valuable clues.
Upstream:
MAF sensor. (I've seen only 2 bad CAT both BK 1., in 98-05. Each had a bad MAF. One replaced with aftermarket (AM) MAF. The AM MAF killed a CAT. The other, factory MAF went bad. It had poor air filtration.
Poor air filtration.
Engine coolant temp (ECT).
Compression
Vacuum leaks
Poorly tuned.
Exhaust air leak(s).
Any fluid loose, where no leaks found. i.e coolant, PS fluid or engine oil.?
Exception to upstream issues:
Impact to CAT (both)
Flood waters.
A clog in exhaust. Such as rodent nest in tail pipe/muffler.
Sure, shoot me a DM with contact info. You can stop by, and will look over together.I can’t thank you enough for this. Honestly, so much of this is over my head. If it’s alright with you, I’ll shoot you a DM to see what my options are. If you can fit me in, I’d be happy to become one of your customers.
FYI, I used to get repeated P0420 codes. I replaced the rear O2 sensors in the exhaust and haven't had an issue since. Very easy fix
What's the best/easiest way to get a reliable ECT reading?It was clear 104f was parks OAT on dash gauge.
I was asking: What was your ECT (Engine coolant temp)?
I ask; because very often correcting a high ECT, eliminates fuel boiling.
Fancy way is Scan Guage. Easy/cheaper way is a $100 OBDII code reader that either has an included dashboard or download a 3rd Party dashboard. A very simple one is BlueDriver.What's the best/easiest way to get a reliable ECT reading?
One of the cheapest way to read the coolant temperature is this type of $1x device: Amazon product ASIN B011NSX27AIt works well, along with Torque on Android, for my 04 LX.What's the best/easiest way to get a reliable ECT reading?
Don't leave it plugged in to the OBD receptacle. Most of those cheap dongles do not sleep.One of the cheapest way to read the coolant temperature is this type of $1x device: Amazon product ASIN B011NSX27AIt works well, along with Torque on Android, for my 04 LX.
I also seem to have alleviated my fuel smell issue by replacing the gas cap, even though there was nothing visually wrong with it.Don't leave it plugged in to the OBD receptacle. Most of rhose cheap dnagles do not sleep.
I highly reccomend a Scangauge II since it is programmable and really not THAT expensive. It also sleeps. I set mine to read my XMSN temp.
BTW, I may have mentioned this above. I had been suffering from some of the usual issues with fuel smells, etc and replaced my gas cap which is often the first step. The new one has been on several months and my issues seem to have subsided.
You are correct that it doesn't sleep which I can confirm, and technically will contribute to drain the battery. However, our LX/LC does suffer slow battery drain regardless of the OBD scanner, and the contribution from the OBD scanner is very minimum, like <xx mA.... For a new battery, it seems not an issue, and I have left it attached and sit for several weeks. However, it's always a good practice to unplug the OBD scanner if plan to leave the LX/LC parked for extensive length of time...Don't leave it plugged in to the OBD receptacle. Most of rhose cheap dnagles do not sleep
I had a cheap one that would kill my battery in 48 hours. Mileage may vary.You are correct that it doesn't sleep which I can confirm, and technically will contribute to drain the battery. However, our LX/LC does suffer slow battery drain regardless of the OBD scanner, and the contribution from the OBD scanner is very minimum, like <xx mA.... For a new battery, it seems not an issue, and I have left it attached and sit for several weeks. However, it's always a good practice to unplug the OBD scanner if plan to leave the LX/LC parked for extensive length of time...
Thank you so much for the insight. Replacement final muffler arrives today and install this week or weekend. Coolant was almost .75 gallon low which gave me real pause. The dash gauge always showed under half but I understand that that is more of a binary response rather than accurate representation of real temp and is also placed high in the block. Follow up questions:Driving with holes in muffler is a very bad idea. Wherever a hole, hot gasses are directed out it. This can be onto wiring, fuel tank, etc., rather than out tail pipe. We're seeing a number of issues, from melting wire sheathing and or wire housing blocks. Also, these holes often result in exhaust fumes entering cabin, through rust holes or open window or bad door seals. Make sure to check the resonator (last muffler) also, for holes.
Your fuel boiled. Which 90% chance in 03-up, pushed raw fuel into charcoal canister flooding it. Which if so, is likely toast.
It's also very likely your engine is running hot. It would be a very good idea to monitor ECT (engine coolant temp) through tech stream, as you drive in 80F plus OAT temps with AC, to determine of so. If you find ECT gets over 200F, you're running hot. Which needs address first thing.
I'm unclear on how heat shield fell off. But all factory heat shields are necessary.
Very likely you were overheating. I always look at why was coolant low, a leak or something else:Thank you so much for the insight. Replacement final muffler arrives today and install this week or weekend. Coolant was almost .75 gallon low which gave me real pause. The dash gauge always showed under half but I understand that that is more of a binary response rather than accurate representation of real temp and is also placed high in the block. Follow up questions:
1. Would you feel comfortable heat wrapping the new muffler as well as the pipes from front resonator back?
2. Regarding evap canister, will its destruction result in codes or simply cause performance issues? The truck continues to run really great with no symptoms of fueling issues that I'd expect to encounter. I have a client who owes me and is going to check it but I'd love to spend that money on a winch mount rather than evap canister if it can be done responsibly.
3. There are MVIC cables in the $50 range advertised as coming with Techstream. I think it might be Techstream light though. There's also places on the internet where I've seen downloads for it. The other option is Bluedriver which seems popular but doesn't seem to be much more than a really good reader. Which direction would you go?
Thank you very much for the insight. I apologize for the large number of questions.
One or any combination other than leak:
a) Coolant system not properly filled.
b) Reservoir, not working as it should. No coolant in it. It's hose hung-up on shelf, curled upward sucking air. Reservoir hose and or it's cap clogged.
c) Bad radiator cap.
d) Bad thermostat.
f) Fuel mixture to lean.
g) Radiator fins clogged, resulting in overheating. Which is so common.
Overheating for any reason. Can expand coolant to point it exceeds capacity of system. It may then, blow out reservoir cap relief hole.
1) I'd not heat wrap, directly on the anything. Air gap the barrier, gives best results. This may help understand why "air gap". Personally, I've never used anything but factory heat shield. Exception is aftermarket CAT.
2) A bad CC often times, does not give a DTC (CEL). It's part of EVAP system and can result in excessive fuel pressure build up.
I like to get all up-stream issue corrected first. If I then still get fuel boil issues, I replace the CC as last step. Also worth a note: The 03-07 owner's manual warns to stop fill gas tank, at first auto-shut-off of fueling pump handle. Overfill may result, wherein CC floods and is damage.
3) I have blue driver for iphone which is close software. It's easy to use. But limited on what (PIDs) it can be read.
I also have the OBDIImx for iPhone, which uses most any open software app. The OBDIImx, allows me to see more. Like AHC pressures, Transmission fluid temps, the list is endless depending on which app downloaded. They both log the data.
