I have the 07 LX that @2001LC has been looking at...
I've had the fuel boiling issue for awhile, happens regularly when offroading in summer time. But have also noticed it on longer road trips in summer, and occasionally around town on hot days in the Denver area. I'll smell gas and see traces of fuel that has come out the cap.. but been around cruisers long enough that I've just accepted it
Few weeks ago had a big fuel boiling issue and a "no start" at China Wall, first time with the "no start" problem and with stream of gas pouring out, so that prompted me to start looking at this deeper. It was probably around 80 OAT and 8500 FT and full tank. We stopped on the trail for a few minutes to discuss route, then I needed my keys to unlock my drawer so shut it down for a few. Restarted, ran very rough and was able to drive for a hundred feet then it died and would not restart. I opened the hood and gas cap to vent, fuel was boiling out for a good 15 minutes. Was able to restart and continue on after 30 minutes or so.
Since starting working with @2001LC, been monitoring engine temps via a ScanGauge after new thermostat, coolant flush, radiator clean out, etc.
On highway and around town, range is generally 190 - 200, usually hovers around 191-195.
After the coolant flush I did drive around that night with both heaters on, 80 OAT and engine temps were between 191-197, coolant level was fine in radiator the next morning.
Also done a couple of trails since:
- Devil's Canyon by Idaho Springs: 66 OAT, 9700 - 10,400 FT, 1/2 tank. No gas smell at start of trail, but definitely once on the trail I could start to smell gas and feel some venting out the cap. On the trail engine temps were pretty steady at 191.
- Pierson Park by Estes Park: 55 OAT, 8600 - 9500 FT, Full tank. Engine temp pretty steady at 190. No gas smell, but was much cooler outside with rain.
We still need to replace fan clutch and radiator cap (was on backorder). Will likely do fuel pump as well.
