Front swaybar quick disconnects revisited and tested
Thanks LCP!
Have to put in a good word for this mod:
I ran my own ugly version of this for many years on my 80. Phil has made an easy plug-and-play version for you. Highly recommended.
Having the front antisway bar disconnected DEFINITELY makes a difference. The front flexes more easily and the truck will be more balanced overall off road. On the highway or at higher speeds though, you want that bar connected to the axle. With this mod it is a snap to disconnect/connect as needed. The truck just has to be on flat ground so there is no force between the ends of the bar. That and you have to lay down in the dirt.
I just realized that I totally dropped the ball on sending payment for these. I've been consumed with some other things. Did I miss my chance?
i would love a pair too, let me know when you have another batch ready!
Hey phil, putting these on tomm and was wondering about the hitch pins vs. the safety pin. Is the SB mounted to the axle with one hitch pin and one safety pin and then when unhooked lifted up to the frame and the same safety pin and hitch pin are used to secure it to the brackets?
I would like to be added to the list as well!
let me know when more is available.
thanks in advance!
Available now?
I hate to ask, but are there any instructions for installation?
Good pictures even?
Perfect, I should figure it out. Thanks, if issues will post.
