Front End Mystery – Help!
Great Falls, MT
1954849
I purchased this 1965 Toyota FJ40 Land Cruiser about nine months ago. From what I can tell the previous owner installed the drivetrain from a '72 Chevelle, so the cruiser now comes with a 400 small block, a TH400 automatic transmission and Saginaw power steering . The front brakes have been converted to disk…… I’ve believe from a early 80s mini truck. I ran into an issue recently after replacing the calipers, finding that the bolt holes for the calipers have been stripped and the PO had used what looks to be JB Weld to hold the bolts in place.
Can anyone help me verify what it is that I have upfront and what options I might have for properly repairing this issue?
Thank you in advance for your insight and help in this matter!
1954850
1954851
1954852
1954853
it looks like a lot of old hard grease to me. although I don't know what is fabed onto your one arm there..... other than that, it looks a lot like the 85 FJ60 I had. just old caked on grease. in need of a rebuild for sure. I don't remember the shocks attaching there though...
The non-vented disks would make it early FJ40 disk or mini truck.
Just as alarming as JB Weld on stripped brake caliper bolts is the funky crap welded to your right steering arm. I can’t fathom why the PO thought that was a better idea than running a factory tie rod end with the hole for the relay rod there.
Edit: oh wait, I see what he did now. He installed the tie rod backwards. Good god.
good eyes @Splangy I looked right past that.
couple options for the threads would be to tap for 1/2" fine thread or run a "heli-coil" type repair.
this also makes me suspicious as to what axle housing they used as a 65 won't readily accept a disc swap
looking at the pics again, the passenger side front cowl mount looks badly compromised, with the exhaust running thru it.
I would have a serious look at the rest of the rig, front to back, my guess is there are a lot of issues, especially with a v8 swap.
looks as tho there is some sort of body lift?? the front fenders are moved up and only using 2 holes instead of 4??
extended shock mount on the front axle?
you can also check in here: MT- 406 Cruisers
For the caliper bolt thread repair I'd recommend a Time-Sert https://www.time-sert.com. I did that on my '86 FJ60 and it worked well.
Thank you for having a look at this for me....... heli-coil is a great idea!
Half the battle with this project is trying to figure out what I have and what the PO jacked up!
Can someone clarify what is wrong with the tie rods?
relay rod should attach to tie rod not directly to the steering arm. i assume the PO saw some of the high steer setups out there that use this configuration and figured that might work so welded a separate arm on. it should look something like this
interesting shock mount too! not awesome but interesting. i would have thought buying a longer shock would have been easier than welding a new mount on!!
Looks like I'm going to need some professional advice on what parts I need to get the steering set up correctly........ a lot of the tie rod end kits state that they aren't compatible with power steering set ups.... :-(
What you have there is a mini truck front end. The reason I say this is because the brake line attachment point for the LC's is slightly different. That would also explain the cobbled-up steering rod configuration. I'm pretty sure the DS steering arm on a mini truck is supposed to be double ended. Back end goes to the pitman arm and the front end to the rtie rod. The PO did away with that setup and blazed his own trail. If I had to guess, he probably cut off the rear section of the DS steering arm and welded it to the PS arm as a pick-up point for the LC relay rod.
