Build Fly By Night
And lastly, tacked the frame side portions of the engine mounts to the frame. I set my clearance of the upper engine side of the mounts, to the frame, at 5/8”. The overhang will get trimmed off.
What are your parking brake plans?
I'm sure you mentioned it earlier, but too lazy to go back and find it :p
I wanted to keep the stock handle if I could, but the word on the street is that you need a ton of pull power to engage the 60 series park brakes. @scrapdaddy and @Voodoocruisers have the lead on an electric park brake engagement solenoid that looks to be pretty sweet.
I run rear GM disc brakes with the parking brake option (El Dorado). But the cool part is the Estopp brake system that is a small winch that electronically pulls or releases the p brake cables. It works well.
That’s the one.
Where did you end up mounting the actuator?
BTW - for everyone else
As this engine mount weld job has gotten closer, I’ve been setting my sights to upgrade my welding game. There’s still several more welding projects to do besides the engine mounts, most of them involving 3/16” - 1/4” steel, so the machines I’ve been looking for need to be able to easily weld those thicknesses and beyond, while only requiring a 220v power source.
Going back to late 2019/ early 2020 when I was fabricating the new spring hangers, I borrowed my friend’s Lincoln Power MIG 255. Loved that machine! Been spending the last couple months looking for one. Long story short, found one 45 minutes away at a good price, so I pulled the trigger.
One of the other requirements I had besides its amperage output, was the ability to hook up a spool gun and MIG weld aluminum. This machine also checks that box. Didn’t get a spool gun yet, but here down the road shortly…
Nice. Kinda, sorta in the market myself.
Had a couple different models from a couple different manufacturers that I was looking at. Was also considering a multi-process unit, but very few of them can do AC TIG at the price range I was in.
