Build FJ55V : This little piggy came home.
Member Build Threads
More progress shots. I need more clamps.
Insert photo here.
1FZFE and Auto box seperated ready for the strip down.
Engine has seen some action. Check the colour on those cams.
Photo from my friend about to start his second dual cab ute chop on the white 80.
The chassis will end up with my project.
Stripped down the Intake of the 1FZFE.
What's the best was to remove the crud and paint. Am I best off sending it to a shop to bead blast or will a pressure washer do the trick?
Vapor hone. It will leave the aluminum looking better than when it was cast
Edit: I forgot you're in AUS so Vapour Hone 😆
Most important letter in the alphabet is "u"
Layered some shiney silver paint on the rocket cover last night. Spiders look to have been attracted to the smell and layed webs across it.
Typical Australian problems.
Third coat to go down tonight after I wash the webs off.
Minestone today.
Sorted out my Gantry and now finally have the 1FZFE on the engine stand.
Super impressed with how simple the engine is built and how easy to assemble/disassemble.
I did however forget to drop the oil from the sump.
