FJ55 headliner ?
Be sure that you know that putting in a headliner correctly will require you to take out the window rubbers. If yours are as cracked and dried out as mine, you may not be able to reuse them. They are hard to find new. I am gonna fab my own headliner with some grey fabric and thin particle board. Home this helps. Hodag
I've never gone custom on the pig, but it would probably run $200-$300 from the local vato loco upholstry store. The SOR ones are good, mine was not exactly cut properly in the front and it sags from me never using adhesive and due to the fear of pulling it tight under the elusive window rubber. I wasn't too sure of what I was doing when I installed mine, so it took a lot of work . Even sliding in the bows was difficult.
Hey, Rush55:
Have you looked at the instructions for that headliner: SOR doesn't say squat about installation, I'm wondering if you have to remove window rubbers.
brider
If "you want to do it right" you do need to pop all the windows - that's what makes it so risky especially w/ the brittle rear window seals.
i did the cheapo style and bought the carpet from auto parts store and got some vinyl floor glue from home depot and stuck it to the roof. it turned out 10x better than i thought. have gotten lots of compliments
Evans link was showing us how he replaced the window seal, that needs to be pulled out so that the headliner can be replaced. Evan did a great job, and hopefully when I attempt mine it will turn out as well.
Evan if you can elaborate a little more on the adhesive you used to glue the seals together, maybe a brand name or part #.
Thanks,
Ryan.
Wow. Really nice, Evan. Did you pop the windshield too? The rear window rubber looks new. Any sources for that?
Chris
hey rush ill set up some pics and let you know how i did it, no screws just glue it looks good
