I recently bought '74 FJ40. What I found in my vehicle is that out of all gauges in my dash board I have only 2 working: Speedometer and Ampermeter, none else is working and my Oil Pressure gauge doesn't even have a needle.
I searched the web, but I can't find any places I can get replacement original gauges. I found a few who refurbish them, but it's aesthetically, not mechanical function.
My question would be - is it worth trying to find any used clusters and/or gauges to strip them for working units? Can I find somewhere OEM or aftermarket replacement in form & fit?
Should I look for aftermarket dash with aftermarket gauges like Autometer or similar? Is it worth in money wise?
How do I connect modern electronic gauges to "classic" FJ inputs? As of Speedometer as an example, FJ is a cable driven, while Autometer is an electronic driven needle.
I found that aftermarket dash board is an average of $80 plus set of Autometer gauges can be around $450-500. So overall cost of converting is over $600 counting all additional harnesses and converter boxes I'd need to buy.
BTW, what boxes and harnesses I may need?
If for some reason you can´t source an original cluster from another Mudder in a reasonable amount of time go with the replacement gauges that Drew sells. (See post #2) His work is top notch and if my stuff ever goes belly up that is my plan. Again as has been said before don´t go down this road until you have broken the cluster down and thoroughly cleaned it and cleaned and checked all of the wiring and each of the connectors and the pins. Good luck.
