FJ40 Gauge Cluster
Lowrangeoffroad.com sells a decal kit. It does require some light trimming, but comes in a wide array of colors to include black. I just did mine and it looks pretty good. I went with white because I'm repainting white. Don't know if I'll leave the cover black or go pewter.
Does anyone know if a later model cluster ('78) is compatible with a 1970 FJ40? I would assume there are major differences but wanted to check with this group.
What about the speedo needle, does anyone sell those? Thanks all, as always...
It appears the fj40 I recently purchased has one of Drew’s cluster kits in it and I definitely would not consider the quality of work up to good standards. Several loose connections and pieces of electrical tape involved. Id rather start from zero than this. Another thing to fix.
I know there are differences between 1970 and 1974.
By 1974, it's using the large round connector for all the wiring except the ampmeter. 1971, it was not.
And the fuel gauges used a differnt sender (different amount of resistance) between those two years.
And I think the plug on the back of the speedometer is different also...
There might be other differences.
For using after market gauges... The amount of resistance (i.e. ohms) for the senders for the stock gauges is documented in the field service manual, I think... For water temp and oil pressure, these are pretty easy to change, but remember the threaded holes are metric, I think the one in the head for water temp are 1/2" BSPT (British something thread something standard, metric version of NPT apparently, but still uses inches?). The search for adapters is annoying, but they do exist.
When looking at used factory clusters I’m seeing a couple slightly different rear boards, one of them having what looks like a 3-prong connector opposite the circular plug and one that does not. Can anyone tell me the difference and which one is correct for 1977?
pics of different clusters
