FJ40 Decals
FJ40 Decal Reference (1975-83)
Decal albums:
Looking for information about FJ40 decals and stickers to complete your restoration? Follow the active links above for albums of decal reference photos and associated information. Additional details on the reference follow. This is a work in progress, please post or PM comments, corrections and suggestions for improvement.
The decal album includes the following:
  • decal index – list of decals with image references and notes, including engine bay decals (A-Z) and interior/exterior decals (1-14)
  • engine bay layout – where the decals are located
  • engine bay images
  • engine bay decal images
  • interior/exterior decal images
The intent of the reference is to identify each decal and show where it is located and how it is oriented, including all decals/stickers: information, caution/warning, and component identification. Ideally the photos will show original decals in their original location. Currently, some of the photos are identified as placeholders (ph), pending a photo of the actual decal.
The decal photos are divided into engine bay and interior/exterior images. There is a layout of the engine bay with each decal location identified A-Z. Then photos of the decals in reference order. When there are several versions of a decal over the time period, the goal is to show each one.
After the engine bay decals are the interior and exterior decals. These decals are numbered. There is not a corresponding layout like there is for the engine bay since the location of these is more or less self-evident.
For the decals referenced, the photo description includes the date range(s). Many also include part number(s). The part number is either the decal part number if there is one, or the part number of the associated part.
Many thanks to Mud member @overton for use of engine bay and decal images from his Land Cruiser Nation web site.
Limitations
The reference is focused on decals, although it may include metal plate identifiers used for early parts like starters and distributors, and data plates. It also may include identifying stamps used on later components like blowers, heaters, radiators.
The reference is also limited to US spec vehicles. While I've no plans to go beyond that, the setup of the reference allows links to albums set up by others, if someone wants to develop an album of decals for non-US FJ40s.
1975-83 FJ40 Decal Reference - Missing Decals List
Need pictures of these decals to complete the reference. Please post or PM photos showing original decals and where they are attached.
1975-77 Decals
A. Emissions Data Detail - 1975 CAL
A. Emissions Data Detail - 1975 FED
B. Vacuum Hose Detail - 1975-77 CAL
B. Vacuum Hose Detail - 1975-77 FED
B. Vacuum Hose Detail - 1977 HA
C. Brake Booster - 7509-7709 44610-60040
D. Air Cleaner - 7501-7709 17700-61030​
F. Carburetor - 7501-7601 CAL 21100-61070
F. Carburetor - 7509-7511 FED 21100-61031
F. Carburetor - 7608-7709 HA 21100-61090
G. EGR Valve - 7501-7601 CAL 25620-61040
G. EGR Valve - 7601-7608 CAL 25620-61041
G. EGR Valve - 7608-7709 CAL 25620-61042
G. EGR Valve - 7501-7608 FED 25620-61020​
G. EGR Valve - 7608-7709 FED 25620-61021
G. EGR Valve - 7608-7709 HA 25620-61050
I. VSV - 7501-7608 CAL 17650-61020
P. Alternator - 7501-7508 27020-61010 12v 40a
P. Alternator - 7508-7602 27020-61011 12v 40a
P. Alternator - 7501-7508 27020-61020 12v 50a
P. Alternator - 7508-7602 27020-61021 12v 50a
P. Alternator - 7602-7607 27020-61031 12v 50a
P. Alternator - 7608-7709 27020-61022 12v 50a
X. Distributor - 7608-7709 CAL 19100-61060​
1978 Decals
B. Vacuum Hose Detail - 1978 FED
C. Brake Booster - 7709-7901 44610-60040 single booster
F. Carburetor - 7709-7901 HA 21100-61091
G. EGR Valve - 7709-7901 CAL 25620-61033
G. EGR Valve - 7709-7901 HA 25620-61051
X. Distributor - 7709-7901 HA 19100-61110
13. Jump Seat - 7709-7901​
1979-83 Decals
A. Emissions Data Detail - 1980 CAL
A. Emissions Data Detail - 1981 CAL
A. Emissions Data Detail - 1982 CAL​
E. Carb Fan - 8001-8309 16360-61024
F. Carburetor - 7901-8007 CAL 21100-61065
F. Carburetor - 8008-8110 21100-61140
G. EGR Modulator - 7901-8007 CAL 25870-61010
G. EGR Valve - 7901-8007 CAL 25620-61070
J. ASV - 7901-8007 CAL 25710-61020
N. Alternator – 7901-7902 27020-61070 55A
N. Alternator – 7902-8309 27020-61071 55A
N. Alternator – 8008-8309 27020-61100 40A
S. Battery - 7909-8006 28897-26010 Danger/Poison
Y. Starter - 7901-7905 28100-60041
Y. Starter - 7905-8206 28100-60042
AA. AC Compressor - 7901-8210 88320-60040
AA. AC Compressor – 8220-8309 88320-60041
13. Jump Seat - 7901-8007​
awesome stuff! just a question, noticed that pretty much all of the decals are for US spec 40's. do you have any for "General" spec. im looking for these for my 1983 FJ45-RPK
Yes, the reference is focused on US spec FJ40s. My understanding is that many of these decals overlap with General spec 40s and with FJ45s. Will leave it to others to figure out and document the details.
Decal reference for 1978 FJ40s (US spec) is posted, see post #1 for the link. Missing a few examples, see post #2 for the list. Please post or PM additions and corrections.
PIO Decal - Port Installed Options Codes
Working on the 75-77 decal reference, which includes the PIO decal. Looks like this one needs to be added to the 78 reference as well.
Here's a stab at what these Port Installed Options (PIO) codes might mean. Based on info from PIO threads listed below.
  • 880 - rear heater
  • 842 - mud/snow tires
  • 811 - am radio
  • 859, 863 - other
The threads identify 9 vehicles with PIO codes, and some indicate how their 40 is equipped in the PIO or other threads. On some stickers, the option code is hard to read, indicated by a ? in the list below.
  • The rear heater is installed on the first 6 listed, and all 6 have the 880 option code.
  • The first 2 also have the am radio, and both have 811 as the other option code.
  • 842 as mud/snow tires is a guess. The 880 rear heater combines with 842 for 4 vehicles. Mud/snow and rear heat seem to be a logical combination. Mud/snow tires also appear as options frequently on window stickers.
  • 859 and 863 only appear once with no other info to indicate what these might be.
Most of the PIO decals list 1-2 options, while most window stickers list 4-5. So which are the port options and which are not? Besides those mentioned, Warn locking hubs, undercoating, and calif emissions requirements are also listed as options on some window stickers. Warn hubs and undercoating are assumed to be dealer options, while calif emissions is assumed to be a factory option.
VEHICLE..........YEAR PIO..CODE..EQUIPMENT
@simps80.........76 - 880? 811 - with rear heater, am radio
@nohuri..........77 - 880 811 - with rear heater, am radio
@KingAir Driver..77 - 842 880 - with rear heater
@Melloj123.......77 - 880 811 - with rear heater
@Big T...........77 - 842 880 - with rear heater
@77mustard40.....77 - 842 880 811 859 - with rear heater
@MTPCRUISER......77 - 842 880
@meat............77 - 863? 842
@yotamotive......78 - 842
_____________________
9 vehicles, 19 option codes
Option Code counts:
  • 880 - 7 rear heater
  • 842 - 6 mud/snow tires
  • 811 - 4 am radio
  • 859 - 1 ?
  • 863 - 1 ?
Other info:
  • PIO decals seem to be limited to 1976-78, based on the examples, installed inside the glove box or on the inside of the glove box door.
  • The numbers on the sticker seem to follow the same order 863 842 880 811 859, this can be useful to help identify partially illegible codes
  • The option frequencies for 880, 842, and 811 are consistent with window sticker options for 1977-78 vehicles listed in the window sticker thread, rear heater(7), mud/snow tires(7), am radio(5).
Additional images:
1976 880, 811 (simps80)
1977 842, 880 (KingAir Driver)
1977 863, 842 (meat)
1977 842, 880 (MTPCRUISER)
Related threads:
Anyone have a glove box door with the white and blue sticker intact?
PIO Sticker what is it for?
1977 FJ40 Option Codes
1978 FJ40 Option Codes?
Nice work Bill-great reference!!!!
Decal reference for 1975-77 FJ40s (US spec) is posted, see post #1 for the link. Missing some examples, see post #2 for the list. Please post or PM additions and corrections.
Made In Japan Decal
To satisfy US import requirements, completed Land Cruisers were tagged with this decal to identify Japan as the country of origin. For such a widely used decal there are very few examples.
This 1975 FJ40 includes the decal on the driver sides, rear corner glass. (sloanstavern)
By 1983, the decal was located on the passenger side windshield and uses slightly different verbiage. (LandCruiserNation)
On another 1983 FJ40. (LandCruiserNation)
The sticker is still in use much later; here it is on the driver side window of this 1998, 100 series Land Cruiser. (bctlex)
The decal also appears on replacement windshields. A newer sticker on this March 1973 FJ40.
Non-Catalyst Decal
The Non-Catalyst decal is located on the drivers door pillar, below the door stop. It appears on 1976-77 US spec FJ40 models. The decal includes information that supplements the passenger-side, under-hood Emission Control Information (Emissions Data) decal.
While the under-hood decal identifies what type of emission control systems are on the vehicle, the Non-Catalyst decal specifies that the vehicle does not use a catalytic converter.
An earlier version of this write-up indicated 1974-77 for the decal dates. Further research suggests 1976-77 instead. The EPA regulation that required the sticker was published June 30, 1975 and described in this July 16, 1975 press release.
According to the press release: "...all light duty vehicles will be required to bear a catalyst conformity statement on a separate label, or the statement may be included on the Department of Transportation label currently required for all imported vehicles. The joint DOT-EPA label or the separate EPA label will be affixed to the driver's doorpost, and will identify the vehicle as either non-catalyst (not subject to bonding), catalyst equipped and covered by a retrofit program (not subject to bonding), or catalyst equipped and not so covered (subject to bonding). The new labeling system, EPA says, will allow Customs officials to quickly determine which vehicles require bonding and which do not."
The Non-Catalyst decal also includes the vehicle model year, which should match the model year specified on the under-hood Emissions Data decal. (JayFJ802)
full
The corresponding under-hood Emissions Data decal for 1976. (lbrillhart)
full
Here, the Non-Catalyst decal (bottom) is shown in relation to the door stop and VIN plate. (LandCruiserNation)
full
Through December 1976, the VIN plate was oriented to face in. (LandCruiserNation)
full
The Non-Catalyst decal faces in as well. (LandCruiserNation)
full
In January 1977, the VIN plate was changed to face out. (Firetacoma)
full
And the Non-Catalyst decal was changed to also face out. (Firetacoma)
full
It is not unusual to see these decals significantly faded or unreadable. (LandCruiserNation)
full
Up through 1977, the under-hood Emissions Data decal did not reference Non-Catalyst/Catalyst. (subzali)
full
That changed in 1978 with the new format Emissions Data decal that includes Non-Catalyst. Revised EPA labeling regulations (section 86.078-35 Labeling) published September 25, 1978 allow the Non-Catalyst/Catalyst designation to be included on the under-hood Vehicle Emission Control Information sticker as an alternative to the separate doorpost sticker. (icorradoi)
full
The Non-Catalyst decal on the Drivers door pillar disappeared after 1977. Repro decal vendors do offer a 1978 version of this sticker. (metrictlc)
full
For model years 1978 and after, the Non-Catalyst decal was no longer on the door pillar and the VIN plate was relocated below the door stop, as shown by this 7709 production date FJ40. (LandCruiserNation)
full
Images of repro Non-Catalyst decals appear to include some anomalies; it is unknown whether the actual repro decals include these as well:
  • U.S.E.P.A in the original decal is rendered as U.S.E.R.A in the repro image.
  • The original decal includes the words “1976 model” on the same line; the repro image has “model” on the next line. The format used for the repro decal is consistent with the 1977 original, but not with the 1976 original.
1976 repro. (metrictlc)
full
1976 original. (JayFJ802)
full
1977 original. (myquestoyota)
Door Pillar Data Plate
The Door Pillar Data Plate is located on the drivers pillar (A-pillar) for US spec vehicles. The plate identifies the month and year of manufacture and also includes the Vehicle Identification Number (VIN). The month of manufacture and VIN are stamped into the front of the metal plate. The manufacture year and other information are printed onto the plate.
The door pillar data plate first appeared on 1969 model-year Land Cruisers to certify compliance with Federal Motor Vehicle Safety Standards (FMVSS) that were the result of the National Traffic and Motor Vehicle Safety Act of 1966. The requirements for the data plate (“label”) are described in 49 CFR 567.4.
Original label requirements included the manufacturer name, VIN, month/year of manufacture and vehicle type (e.g., truck, MPV, bus, trailer). Later, requirements for Gross Vehicle Weight Rating (GVWR) and Gross Axle Weight Rating (GAWR) were added.
Attachment requirements for the label are described in §567.4(b): The label shall, unless riveted, be permanently affixed in such a manner that it cannot be removed without destroying or defacing it.
The door pillar data plate information is useful for:
  • Confirming the Vehicle Identification Number
  • Identifying original vehicle specifications/features/options using the manufacture month/year
  • Determining the correct replacement parts for the vehicle using the manufacture month/year
  • Distinguishing hardtop/factory soft top versions using GVWR/GAWR information
March 1969 – August 1969
An April 1969 plate. The first plates are quite different from later versions. These plates were used with 9-character VIN numbers (e.g., FJ4012345) exclusively. Plates were located above the door stop and positioned to be readable from inside the vehicle. (GRAutoGallery)
full
September 1969 - December 1971
In this version “Manufactured By” is fully spelled out in the first line and the lines are centered on the plate. Most of these plates have 9-character VIN numbers. The change from 9-character to 10-character VIN numbers occurred in mid-April 1971. (93jspec)
full
January 1972 - December 1974
The lines on this plate are left-aligned. Except for the manufacture month/year and compliance statement, information is presented in a Label: Value format where the colons are aligned. New information includes the GVWR and front-rear GAWR expressed in pounds: 4665 / 2120 - 2545. (sl10002001)
full
Hardtop / Factory Soft Top Differences
The GVWR and GAWR values are different for hardtop and factory soft top vehicles.
November 1973 hardtop. GVWR/GAWR: 4665 / 2120 - 2545. (GRAutoGallery)
full
November 1973 factory soft top. GVWR/GAWR: 4540 / 2105 - 2435. (Colorado Boy-74-FJ40)
full
January 1975 – August 1975
Same format as the previous plate, but with different GVWR and GAWR values: 4860 / 2195 - 2665. This is the hardtop plate. (Jaimer3)
full
July 1975 factory soft top. GVWR/GAWR: 4740 / 2185 - 2555. (Autotrader)
full
September 1975 – August 1977
Changes include new GVWR and GAWR values: 4885 / 3195 - 3195. This plate introduces the “FJ40-” VIN prefix printed on the plate instead of stamped. Although the orientation of the plate changed in January 1977, the same plate was used through August 1977. (Vae Victus)
full
Through December 1976, plates were oriented to face in. (LandCruiserNation)
full
Beginning in January 1977, plates were changed to face out. (Firetacoma)
full
September 1977 – December 1979
In September 1977 the plate format changed significantly. The length of the plate increased to 120mm. Information about tires, rims and tire pressure was added to GAWR. GVWR and GAWR values are expressed in kilograms as well as pounds:
GVWR / GAWR (front-rear)
4885 / 3065 - 3220 pounds
2215 / 1390 - 1461 kilograms
(LandCruiserNation)
full
Starting in September 1977 the plate was relocated below the door stop, still facing out. (LandCruiserNation)
full
January 1980 – August 1980
Same as the previous plate, except that it has 60023 along the left edge. This may be a part number reference. (LandCruiserNation)
full
September 1980 – June 1982
The 17 character VIN numbers were implemented starting in September 1980. The plate format changed in that the “FJ40-” prefix was no longer printed on the plate. Additionally the 60023 left edge designation was replaced by 40-2 and what appears to be a part number, 74514-60024-, was added along the right, lower edge. This version appears to use a smaller font for most of the printed text, although the manufacture year is a larger, bold font. Fractions are expressed using separate characters (1/2) rather than a fraction symbol (½). (LandCruiserNation)
full
July 1982 – December 1982
Effective 1 July 1982 the Toyota Motor Corporation was formed from the merger of Toyota Motor Company and Toyota Motor Sales Company. The previous plate was changed to reflect the new company name. (LandCruiserNation)
full
January 1983 – August 1983
The last version of the plate started in January 1983. The only change in this version is the “A” following the part number, 74514-60024-A. (LandCruiserNation)
full
Door Pillar Data Plate Summary
full
The late model plates have an error. The 81-later USA Cruisers (FJ40 & FJ60) use a 15x6jj wagon wheel. Chrome on FJ60 LG, white on FJ40 & FJ60LV. Not a 15x5-½ as on earlier models.
FJ40 Fender/Firewall Data Plate Reference
See the FJ40 Fender/Firewall Data Plate Reference album for examples of fender/firewall data plates from 1961-83. This is a work in progress, please post comments, corrections, images of missing plates or better images of current examples.
The album includes example fender/firewall data plates from US spec 1961-83 primarily FJ40s. A few FJ45s since they use the same plates. Listed by model year for early plates. Plates are located and attached:
  • 61-6608 passenger-side firewall with screws
  • 6609-7708 passenger-side fender, see specific plate for screw/rivet attachment
  • 7709 passenger-side firewall with rivets.
1961. This black plate was also used for FJ25s. The 1 at the beginning of the frame number indicates the vehicle build year, which may be different from the Model year. The number at the beginning of the frame number was discontinued in 1965 and replaced with the brass tag.
full
Format change in 1962. Same information as the black plate, except Piston Displacement is now expressed in liters instead of cubic centimeters. TEQ logo appears on the plate.
full
Format changes sometime in 1965. The Type field no longer appears and the model code (e.g., FJ40L) now appears in the Model field instead of the year. The Engine No. field no longer appears and Bore, Stroke and Piston Displacement are now specified in inches/cubic inches instead of millimeters/liters.
full
Late 1968. Several format changes for this plate. Includes the wording "Toyota Motor Co., Ltd. hereby certifies that this vehicle conforms to all applicable Federal Motor Vehicle Safety Standards." This wording moves to the door pillar data plate in early 1969. Plate only includes Model, Engine Model, Piston Displacement and Frame No. information fields.
full
1970. This plate is located on the passenger side fender and attached with rivets. The content of the plate is emission control information and the Frame No. The emission control information would move to the under-hood sticker in 1972. The change to rivets is probably the result of a requirement that emission information be permanently attached.
full
By mid-72 the emission information is no longer on the plate. Plate is now attached with screws. The plate and plate format are identical to the 1965 plate.
full
Late 1974. Displacement in both cubic centimeters and cubic inches is included on this plate. Consequently "Piston Displacement" was shifted left to provide room. Bore and Stroke are specified in both millimeters and inches.
full
Early 1975. Significant format change in 1975. Bore and stroke no longer appear. New information includes the color/trim codes, transmission/axle codes, and plant code. Piston Displacement changed to reflect 2F engine.
full
Mid 1975. Another format change. This plate has the number 60151 and has two holes for attaching. Plant code is now printed on the plate instead of stamped. The number 0-4 appear at the right side of the Trans/Axle line. Although this plate is attached with rivets, some other 2-hole plate examples on the fender are attached with screws.
full
Early 1976. The plate number has changed to 60152. The 0-4 has changed to 0-12. This plate will be used until 1981.
full
The plate moves to the passenger-side firewall in 1978. Factory attachment from then on is always with rivets.
full
1981. New plate format to accommodate the 17-character VIN number. Plate number is 60340.
full
Effective 1 July 1982 the Toyota Motor Corporation was formed from the merger of Toyota Motor Company and Toyota Motor Sales Company. The plate was revised to reflect the new company name. TEQ logo no longer appears on the plate.
full
Couple notes on the early ones:
Not all FJ25’s came with the black plate. By 1959, some came with the style you have listed as a 1962. This curious use of two different VIN plates continued into 1961 FJ40 models.
@wscbill, thank-you for your research and efforts to compile and format all this.
Ditto. This is the kind of stuff that makes MUD the BEST resource.
Measure Of Engine Adjustment / Toyota Improved Combustion decal
There are relatively few original examples of early versions of this decal, and no examples of originals after 1973. If you have them, please post images of missing examples (66,70,74-78), or better images of existing examples. Images of repro decals are used for illustration, but repros may not be exact representations of the originals. Dates are estimates based on limited information provided. Additional examples will help to confirm.
This decal appears from at least 1962-78 on F135 through 2F engine value covers. It started as "Measurement of Engine Adjustment". The earliest example is from 1962.
full
Changing to "Toyota Improved Combustion System" in 1969. The last version was discontinued after 12/78. By that time, most of the information on this decal was also on the "Vehicle Emission Control Information" decal located under-hood on the passenger side.
full
Early versions were located on the driver side valve cover.
full
In 1968, the decal moved to the top of the valve cover, towards the back, facing the driver side.
full
In 1975 with the larger air cleaner covering the top of the valve cover, the decal relocated to the passenger side.
full
1962-64. Includes the "Specific Gravity" line. Interesting typesetting on these early stickers. The double quotes preceding (EXHAUST) are positioned quite low. For the decimal values, the decimal point is sometimes located closer to the leading character (0.4, 0.5) other times closer to the following character (0.25, 1.27). The tilde characters (~) have varying lengths and different shapes. The values for the last two lines are sometimes left aligned, other times indented by varying amounts.
62
full
63
full
64
full
1965-67. "Specific Gravity" no longer appears
65
full
67
full
Another 67
full
1968-74. The decal moves to the top of the valve cover. Background color changed to white. New information includes Ignition Timing and Idle Adjustment. Black letters on this decal.
68
full
69. Decal name changes to "Toyota Improved Combustion System". Plug Gap, Dwell Angel, Firing Order and Float Setting specifications no longer appear. The Idle Adjustment steps listed on the 68 decal are summarized in Idle Setting, and Positioner Settings was added. Letter color changes to blue. This is a repro decal.
full
71. Idle Settings changed to 600 RPM.
full
72. Positioner Setting changed to 1200 RPM
full
73. Idle Setting changed to 650 RPM.
full
1975. The decal is relocated to the valve cover passenger side. The 2F version of the decal includes 2F in the green square. Idle Settings changed from Lean Best Idle to Lean Drop Idle. Positioner Settings now distinguish Fed and Cal specifications, Fast Idle Speed setting added. Dwell Angle added back, and Point Gap changed to Plug Gap. Letter color changes to green.
The parts catalog identifies 2 versions of the 2F decal. This is a repro decal, unclear which version.
-11293-61020 – (01.1975-08.1976)
-11293-61021 – (08.1976-01.1979)
full
Summarizing this decal.
full
The picture credited to me above is actually not a picture I took, I don’t think. Great thread though!
When did Toyota drop the numeric prefix from the VIN?
The 40 Series Registry lists 4-FJ40-25309 (early July 64 build based on the VIN table), and here's an example without the leading numeric, FJ40-30300 (August 64 build). Not definitive, but suggests an August 64 (FJ40-30276) time frame.
full
