Build First Vehicle to work on - FJ40
Sand blasted parts can easily get flash rust, but I've not seen it that fast - were you touching them with your bare hands, or was it very damp perhaps??
No, I wear gloves. It's all over the part... I guess I treat it with ospho. And then wash it with mineral spirits and sand it a bit with scotch bright... Well kinda disappointed after I had that nice finish of the blaster :D but I guess you can't have it all.
Chicks are relaxing next to their new home. Finally done soon. Daily omelettes here I come!
Hello again,
So Ospho is not a good idea an big surfaces with a lot of texture :/ sanding this is not a nice feeling as it's still aggressive and the only gloves which are chemical resistant have bad grip feeling for the sanding cloth... So I do not recommend doing it this way. Sandblasting and then directly coating is definitely the way to go as everybody said already 😀
Another big let down is the metal paint Brantho Korrux. It immediately scratches and at the slightest bumping against it cracks or gets a nick... I decided to Sandblast the parts I painted with it again. Knuckle head etc. I wanted it to be durable. That's why I went with Zinc dust Epoxy Primer. I feel like that's a good decision after seeing the first results.
I decided to go Polyurethane on these Parts as top coat. The big parts of the frame are Powdered and I will get them tomorrow! Looking so forward to that.
And the tub of teseven from France looks absolutely amazing. He sent me images of the manufacturing process. I asked if I can share them here. Waiting on his reply. I think these will be by far the best aftermarket steel tubs out there. The level of detail...
I'll keep some more pics coming
Cheers
Hello hello
Parts parts parts, they are here!
Ive decided on the tires and got the split rims in. I went with a slightly bigger diameter since i get a 2" lift and i think the spacing shouldn't be too big. It actually was quite a task because in Switzerland the tire and the rim must be tested from a specific agency. So it must be a match or else you need to contact that agency to do these test for you specifically, which is quite expensive. And when you increase the tire size by more than 8 percent you need this as well. A lot of bureaucracy...
Did a lot of spray painting. Ive bought this spray booth but im not sure it was a good buy. After a few minutes its unbearable to be in there. Even though it has a ventilation the concentration gets so high it bypasses the filters i wear and it gets intense. So i think i will use it outside and open the rear door. I guess its better than directly outside.
Next up i will get the third members blasted and paint these ones too and then i will get help to rivet the frame together. Afterwards i can get her on her feet. My plan is riveting und some of the assembly till end of august.
And yeah who would have thought. I cam across another project. Had to buy it. As we will be moving in it for some time. Lets see how much it does interfere but it already does heavily with space :D
BTW Tesevens Fabien said he doesnt want his tub pics published. He publishes fotos on his social media accounts.
Have you tried an air-fed mask in the spray booth?
Get a separate small compressor for it with a good supply of fresh air
No i didnt and i also didnt know this exists! Thanks for bringing it up. Im already checking the best place to buy one of those :D
I have a question to the US People in here. I try to get these heavy duty seals:
But i cant wrap my head around the shipping price... I mean this is almost the same amount i paid for a winch and the front bar... I cant pay 203 dollars for this. So could someone send this to me and i pay them the seals. I think regular mail would be way cheaper... Really hoping someone can help me out here.
UPS ground to idaho for one is $15
Shipping to Canada from Marlin Crawler is $138 for UPS expedited, but only $30 for UPS standard. I’d email the seller and find out if they can send it USPS (Unites States Postal Service) or UPS Standard (rather than expedited).
Marlin’s pinion seals are 1/2 the price to begin with. If the seller will ship by an alternate means, it’ll cost less than paying to ship it to one of us and then having us ship it to you,
I’ll do it if you need. DM me.
Thanks I will try that! I'm soon in need of the seals.
Friday the frame gets riveted. So I'm in preparation. Very much looking forward to get the wheels on. Big milestone I think.
Does someone just of the bat know if the bump stop is also riveted?
Bump stop bracket is bolted on.
Pictures !
So I'm in full preparation mode. I think I got everything set up and need to only paint four brackets until Friday.
I reassembled the frame and started to fit in some of the parts which are beeing riveted on. I hope we can do this cold, I don't want to destroy that coat already. But I think it will be good none the less. The extra coating is so nice already. I'm glad I took it apart.
And I got mail again. Some bearing pressing and pulling kit and new parts!
Somehow I think I already dirtied my sandblasting media, whenever I blast something it seems to be greasy and smeary
... I think I need to clean the whole cabinet and all parts and renew it or something else... I don't think it's normal that I need to clean the parts after the blaster right?
Cheers
Riveting postponed till Monday... Time to blast and paint the thirdmember.
@bikersmurf thanks for the tip, I contacted the them and got a decent quote for 60 bucks shipping, and added the breather hose for the diffs. Didn't know about that even being a thing but sounds like a reasonable improvement.
Slept in the shop 🥱 was drilling and preparing all night.
Seesh life is hard when you dont know how and what you are doing. I made a mistake with my planning. When i removed the rivets i did this in one go not realising there are parts which are riveted to inner frame and parts which are riveted to the frame rails before they were both riveted together. We fabricated the weirdest tools to get to some of the places and instead of one day we are already working two days on riveting and we have not flipped the frame yet to attach parts from the top. All in all it is really some physically exhausting work. Cold riveting is nothing to joke about. So after about 10 cold rivets we realized we can not do it. So we started to do hot rivets. And the downside is us burning the coating massively in some places... Also of course missing the rivets with the hammer some times... The Thor Airhammer is to weak to do the job by itself.
We are too far in to detach the inner frame so we got to get through it. Im a bit worried about the inner frame and its coating beeing destroyed where the rivets are. I sent in some of the pictures i share here to the coating guy and he pretty much said i need to sand down all the damaged places and then he will coat it all again. I was unsure about the last step in any case since the rivets have no protection now. Still after doing it im not sure what the best way would be to get this done.
Hot riveting destroys the primer and any topcoat but i wanted protection between the two frames. So it was inevitable in a way but it seems like there should have been a better way.
So in two weeks the journey continues.
So the goal is to get the frame done before the end of september to get it to the coating guy again. I leave for 2-3 Months to another place so the time is used in a way.
Working on the frame made me realise that i just have not enough knowledge overall so i enrolled in a mechanic course over the next 12 months. Im so looking forward to drive that car!
Pictures !
So I took a break from riveting since my colleague can’t join me the next days. Instead I started working on the third member. Took it apart, got some paint on it, and then quickly realized the bearings need changing. Sand made its way into them and with the rust almost everything feels rough.
Started stripping it down and cleaning a few pieces. Some parts turned out really nice and are reusable — the pinion bearing for the rear diff for example. That’s already a win. But I’ll probably pull the carrier bearings and replace them. Also swapped the outer bearing for the shaft at the backside of the differential.
Would be glad for any advice on what I should really watch out for when putting all this back together. I skimmed through the factory service manual and there’s quite a list of measurements. I get some of them, but of course I didn’t measure anything before tearing it apart…
Next steps: finish taking it all apart, wash everything properly to get the sand out, and then start reassembly.
Cheers
I started to pull apart the rear third and it so rusty inside it's all orange red. Im glad I took it apart as I can see now it has many rust flakes inside and the pinion bearing is crusty. I think since I have them both open I go for full bearing replacement. What can go wrong. I probably will not open them for a long time afterwards. At least I hope so.
I used damp cleaning tools and some motor cleaner to get the oil away it's a lot of scrubbing, damping, spraying and repeating this over and over but I think I can even get the gray back of the inside. Just want to make sure that rust and sand is gone. So far so good.
Monday is riveting time. We hope we can finish it. That would be so nice.
I learned so much already. I started to use chatgpt on the forum and it finds almost everything I searched for so far and does a comprehensive summary of the various subjects. Maybe we should build a bot with the forum knowhow.
Hello Hello. Finished my hibernation in Portugal and back to a freezing cold workshop! Finally i was missing that skeleton of a car.
Frame is done. Rivets coated. Everything ready for assembly.
Working on the Thirdmembers, bearings pressed on and now waiting for the pinion nut to arrive before i can continue. I built a small jig from scrap parts and a pipe. Works very well to handle the differential bearings so far
Started to assemble the axles and leafs springs. These U-Bolts seem awefully long. I cant tie them with my socket wrench. Is this supossed to be like this? I got the terrain tamer kit and am also a bit dissappointed that there were no anti-inversion shakles in there. I know my fault but i thought this is standard...
Looks great. The important part of the U bolts is if you have enuff threads to get them tight. You'll have to cut them once it's all done. Don't forget you may have to use caster shims to get the steering geometry within spec.
Instead of pressing bearings on you can stick them in an oven or on a hot plate to heat them up. The metal will expand and they should slide on the journal.
Ah, thanks i didnt know! So another task to come i was not aware of yet.
I did that with the pinion because it would fit my freezer. The rest i had to press.
Does anyone know if this is normal? The rear axle looks tilted. And im not quite sure if this is supposed to be like this. Also in which direction the leaf spring will move under load. I really think the anti inversion wouldnt be too bad. Unfortunately i cant find terrain tamer pics of a truck with 0 weight.
