I literally did this conversion without doing anything else downstream. Has worked ever since. Reason being I couldn’t afford to do it all at once so why not see what’s upAm I correct, the general wisdom is install the new pump and then see if the steering box has an issue or is it better to take out the box at the same time and have it re-built? Thx!
This is the belt we supply with the kit snd have been since day one.Real Time Help Requested - I'm looking through this thread, but can't find the specific information I want. I've done this conversion and I'm loving it, but my alternator/ps belt just shredded and I need order one that fits. If I remember correctly, the Toyota factory belt it too thick for the new pulley. Yes?
I have to start the 60 one more time to get it home, and the steering is very old school at the moment. I'd like to fix this ASAP.
Does anybody know what belt I should get (from O-Reilly's, AutoZone, Napa, etc..)?
Thanks,
Russ
Found another thread that pointed me to a Duralast Belt 17620. Poppin' Belts - https://forum.ih8mud.com/threads/poppin-belts.1133736/page-2
Hope that helps.
Georg @ Valley Hybrids @ Cruiser Brothers
Do you still have the conversion kits? I want/need to upgrade my pump but I don't really have the tools to modify the existing bracket.We've never run into issues with the sag pumps "blowing seals out" on either the FJ60, Minitruck or other Toyota PS boxes.
Obviously if the seals have never been replaced, then it's not a terrible idea to do so. Parts are fairly inexpensive and everything is readily available at the dealer or from vendors such as Beno, myself and others on here.
And replacing the input seal and o-ring ( the most common leak by far ) is a very simple job.
I have plenty of the kits in stock.
Thanks again for all the support and orders, I appreciate it!
Georg @ Valley Hybrids & Cruiser Brothers
Yes sir!Do you still have the conversion kits? I want/need to upgrade my pump but I don't really have the tools to modify the existing bracket.
Thanks for the post and question. We have thought about it, but the OEM pumps are still available new. The 62 pumps are also much lesstroublesome when it comes to leakage since they were not located near the exhaust, like the previous generation with the 2F.Question for you Georg, mainly to satiate my curiosity; do you have any plans for a Saginaw conversion kit for 62s? In my case it wouldn't be any kind of upgrade (I have an OEM rebuild kit for when my pump starts groaning again, plus I'm not planning to go larger than the 33" tires I already have and I don't do any heavy wheeling), but I know others would be interested, plus if availability of 62 pump rebuild kits comes to a halt, there's going to need to be a viable alternative and Sags are seemingly always readily available.
Thank you for that. I'm doing this project for my daughter and I'm not getting any younger. I just her set up right. ThanksI think that you may be over thinking it just a tad. It's simply a Saginaw pump. There are a few iterations/differences between them. The shaft is either a keyed fit or tapered fit, a couple of options for mounting holes, and two options for the high pressure line fitting (SAE or metric). Far more than just two pumps available. If you want a high quality, high pressure new pump, I bought a PSC pump that's on my CJ-7 crawler. I put a cheap parts house reman pump on m6 FJ60 and it worked great.
Do you know a source?I highly reccomend sourcing the 3D printed adapter for the factory Toyota PS cap when you do your swap! Makes for a cleaning, factory looking install.
I believe that it is discussed earlier in this thread. I'll see what I have.Do you know a source?
