Finally!!!! Saginaw PS pump conversion kit for FJ60s!!!!!
Hey y'all! Way back in 2017 on page 12 of this thread @BigRiggs posted about his nifty little adapter to get your old "Toyoda" cap on the Saginaw reservoir cap. I ordered one from him a while back and then got to talking. We worked things out to where I'll now be selling these through my web shop. Current production will be a cast urethane resin. Brendan's 3D prints worked great for me, but the new product is a little more heat tolerant and maybe a slight bit more grippy. It's also now keyed to the raised "T" section of the Toyoda cap for a little better transfer of the turning force. New and improved I guess, but not to downplay the good work Brendan put into the original.
You can find those on my web shop here.
As with before, you have to bring your own Toyoda cap to this party, along with the Dorman 82581 cap for the Saginaw pump. I will include detailed instructions with every order to help you through getting the Toyoda cap liberated from the dipstick portion - that can be a real pain.
Alright, I'll hand the thread back to Georg now!
Happy to see you add this to your lineup & that you were able to work out a deal with Brendan.
I’m thinking that maybe we should stock a few of these so we can offer them with the conversion kit. That way our customers can get everything for the kit from us instead of having to deal with multiple vendors and shipping charges.
Thoughts?! Send me a text and tell chat!
Georg @ Valley Hybrids @ Cruiser Brothers
Absolutely Georg- the thought already occurred to me and you were on my to-do list. I’ll be in touch.
hello , where can i pick up this kit in nordics euro`?
im confused anyway but want to get the 1200 psi saginaw or same on my 1982 fj60 2h.
then later add the hydro assist .
4H snow is less and not happy i know that,
thank you btw if you can help me discover the right kit -
Question: any ideas on how to find one of the original caps? I guess I could buy someone's old steering pump just to harvest the cap but that sems like such a waste. My wife somehow bounced my original T cap off of my adaptor plate, super bummer. I thought it was so tightly on there due to the friction alone there would be enough but I was wrong.
I would think any of the usual parts yards would be able to help you with that. Classic Cruisers is probably worth a call.
I don't think this has been posted yet.....I've had my Valley Hybrids @orangefj45 conversion for years now and it's been great. Just converted my front axle to 80 series and upgraded the steering box. I FINALLY added the magnetic filter I bought over a year ago.....the TECH:
I searched all my parts boxes knowing I had the right part. Final found it....the HAC bracket/holder is the PERFECT fit for this filter. I riveted it to the fender w ss rivets. Pretty cool.
@CruiserTrash Now I just need one of those cap converters.
Ready when you are! I got a bunch on the shelf and I'm happy to send one.
FYI, that's the best color 60 isn't it? I might be biased...
Just completed my Saginaw PS pump conversion, @orangefj45 kit is awesome makes the process easy. My only hiccup was my fault, since I am running a FJ 62 alternator on my 60 the supplied belt was a little too big. So I went to auto parts store and sourced another ( Gates 9610HD ).
Belt question:
Stock drivetrain US-spec FJ60 with the Saginaw pump... The recommended pulley for the Saginaw has a narrower groove than the Toyota pulleys. It was suggested to run the narrower belt. Under heavy load I'm getting a belt screeching noise in 1st & 2nd gear around 1700+ rpm - basically when trying to accelerate from a stop and rowing through the gears. The narrow belt definitely rides all the way down into the groove of the alternator and crank pulleys and not on the sidewalls like it's supposed to. Of course the belt fits the narrower Saginaw pulley perfectly. I've had the Sag installed for a few years now and it's been fine, this noise just started happening a few months ago.
Any solution to getting a correct pulley for the Sag, or a better in-between sized belt? Some kind of magic ticket for making two incongruous things work together?
@CruiserTrash I can post the belt and pulley I'm running when I get home......it did come with the kit from Valley Hybrids.
Thank you! I’ll have to dig up my notes from that project to compare, but I’m 99% sure that’s the pulley I used. Narrower groove than stock, right?
Yes I think so....or at least it sits further in the pulley on the crank and alternator.....maybe same pulley size but the ps pump is not as deep? Hard to say, but mines been great since the upgrade.
Hello!
I recently installed this kit (the second one I've done) and am wondering about the alignment of the p/s reservoir and pulley.
The p/s pulley is flush w the end of the spindle. However, when putting a square edge across the face of the alt pulley and the p/s reservoir pulley, there's a approx. 1/4 inch offset., with the p/s pulley farther back. The pulleys are different widths, but the centerline of the each pulley still still seems off.
I had the same alignment issue on the prior install (and using an 80-series alternator) and the belt to wore/broke prematurely.
I can't see that there is an issue w the mount to the engine block or within the kit parts, so it is likely the length of the p/s pump spindle? Has anyone seen differences in power steering pumps? I need to dig up the number, but it was one of the parts recommended here...
