Build FARM USE
With a cutoff wheel I cut reliefs where pin was stuck and they came out.Installed M8 10.9 grade bolt and welded. Should work. My guess other side will do same thing by end of summer.
Installed better windshield and hood latches. Now I dont think about the hood latches failing doing 55. Installed new shocks. The old ones were doing nothing. Probably original! Next is new shackle bushings. Am I crazy to think I can reuse the shackles?
Truck started to smoke during extended idling time. Found #5 cylinder leaking some oil through valve stem seal. Figured I will change all 41 year old seals with new this weekend.
Did this job on my 3FE. Springs may be a little different on the F/2F but I personally didn't have much luck with that spring compressor. I ended up renting the OEM Tools one from the 'Zone, YMMV and I'm sure this isn't your first rodeo. Link to my thread here.
