Did you get them in yet?The Rubber seals australia kit comes with new Wedge things for the outside of the frames but i just cleaned up and reused my old ones. The wedges are NLA from toyota, if anyone wants or needs a full set of 8, give me a shout and you can just have mine. They dont have adhesive on them so you can just use the 3m goop that you use to glue the windows in on the wedges to stick them to the frame.
I ran out of time tonight. Theyre literally ready to go though. All i need to do is pop my old windows out and put the new windows in on the body of the truck. I would have done at least one tonight but i am still trying to figure out a way to get the old glass out with one person. You need someone on the outside to catch the glass when it releases from the rubber trim seal or it will just drop to the ground. Theres got to be some kind of way i can rig it up to not fall and shatterDid you get them in yet?
Use masking tape.I ran out of time tonight. Theyre literally ready to go though. All i need to do is pop my old windows out and put the new windows in on the body of the truck. I would have done at least one tonight but i am still trying to figure out a way to get the old glass out with one person. You need someone on the outside to catch the glass when it releases from the rubber trim seal or it will just drop to the ground. Theres got to be some kind of way i can rig it up to not fall and shatter
I dont think masking tape will support the weight of the whole windowUse masking tape.
Limited-time deal: EAMOMORK Suction Cup Hooks for Shower, Large Clear Heavy Duty Suction Cup Hooks, Wreath Hangers for Front Door Window Glass Kitchen Towel Loofah Utensils (8 Packs) https://www.amazon.com/dp/B08T1BJR72?tag=ihco-20I dont think masking tape will support the weight of the whole window
When I pulled my windows to tackle a couple small rust spots under the seals I used these suction cup hooks, put a couple on each window and tied it to my roof rack.Just make sure there is enough string to let window come out but not drop and pull suction cups off. They held long enough for me to get window out and then go grab it before any disaster happened.
huh good to know. Getting the old windows out is the only step left between me and installing these. I might take a crack at one on my lunch break!@dbbowen I was worried about the window falling out too, but that never happened. Once you have 872 screwdrivers across the top of the seal it’ll start coming loose. I went down the sides about 1” past the end of the curve. At that point the top seal is past the pinch weld just a hair but the window is still being held in by the rest. I went to the exterior and was able to get a thin pry tool and my fingers on the top edge and start pulling the window out. I folded it down to pull the seals on the edges past the pinch weld, then put as able to lift it straight up and off the bottom part of the seal.
I had an elaborate setup taping the window to my roof rack … didn’t need it.
That's cool. Thanks again for putting this information out there and putting together the group buy. I'm looking forward to doing my own in due time.Windows are done. I forgot to put the small plastic piece in with the two holes in the center and the wiper fuzz in both windows like an idiot. Windows still function fine, they just tilt when you slide them. At some point ill pull the windows back out to add the forgotten part. What a bummer.
Anyways, install was super straight forward.
In all reality, I just spent a ton of time and money so my dog could stick its head out of the window
@dbbowen Wait … the glass is available NEW???glad you got this solved for everyone involved even if it cost a lot.
FYI for other folks interested, my glass was incredibly difficult to remove from the frames and there’s zero chance mine would fall out. Brian and I discussed that our frames looked the same but maybe had slightly different tolerances or something. Point being: better to be careful and assume your windows can fall out during install or removal, than assume they won’t and have it happen. And yes, the little tiny “hat” shaped piece with two pieces of felt on it is absolutely necessary. It goes at the top of the post. I thought it was only to wipe water off the tops of the glass, but apparently it must provide some downward pressure on the windows to hold them tight as well. The part number should be in the previous posts I made on this thread.
Here’s an old one
New one positioned on the top of the post (I bought new 80 Series posts and cut them down)
Great tip on using butyl to remove the butyl, that worked for me too. On my glass I used 0000 steel wool to buff out scratches and marrs. You have to apply very little pressure to avoid swirl marks, but it works well to make the scratches go away about 75%.
The group buy already took place but maybe someone has an extra setup?I would like a set for my 60. How do I get in on the group buy? I am located in Atlanta.
Darn it. if there is an extra set I’ll take it. ThanksThe group buy already took place but maybe someone has an extra setup?
I ordered two 15’ rolls@dbbowen @CruiserTrash @red66toy: whoever answers first. Was 15’ of the 3m butyl tape enough for both windows? I’m hoping to get my windows installed in the next week or so but I’m not where I can measure the opening right now and wanted to get the butyl tape ordered.
