Engine Going Dead With Breaks Applied
Georgia
My engine is dying when I apply the breaks. It goes slowly. When it is cold or warm. It does not matter how hard i press them (ie slamming on).
I have a 79 40 with a weber carb. No other engine mods.
I have no electrical probelms (right this minute). Batts are fully charged. The breaks are fairly new and in good service. It has only recently been doing this and has only been happening since it has gotten hot.
Please help I feel like a douce having to restart after every stop light/sign.:doh:
1973Guppie said:
just for curiousity's sake, what causes this exactly with the brake booster being bad? just interested in learning what happens and why....
Noah
Brake boosters use a large rubber diaphragm and engine vacuum to "boost" the pressure you apply through the pedal. When that diaphragm goes bad, you not only loose the effectiveness of the booster but it introduces a vacuum leak into the intake. Instead of the engine vacuum just pulling on the diaphragm, it pulls outside air into the intake.
The only thing different about this vacuum leak than any others is that because of the location of the brake booster hose on the intake manifold, only cylinders 5 and 6 see a seriously lean condition from this leak, and hence you often see old engines with cooked valves or other lean-condition problems on cylinders 5&6.
There you go, more than you cared to know about leaky brake boosters.
:cheers:
What caused my booster to fail was the brake master cylinder rear seal. It failed and leaked brake fluid into the booster which eventually caused the seals in the booster to fail. I removed the four nuts holding the master cylinder to the booster and just pulled the MC forward without removing the brake lines, the leakage into the booster was quite obvious.
Fast Eddy said:
Mine only leaked when I pressed on the brakes. It would idle fine otherwise.
Yes, as noted in the first post, it only dies when the booster leak is activated by stepping on the brake pedal.
My point was that if you stepped on the brakes and revved the engine at the same time it wouldn't die because the manifold leak isn't as big of a problem with the throttle open. It will only die if it is idling and the leak is activated.
If it dies at all RPM's then look for an electrical problem (short in the system between the brake light and ground). If, on the other hand, it only dies at idle I'd second the thought of PinHead.
Good luck!
