That's on the list. Just picked it up for 3100. Needs a little work but its getting there.
Yep, it should.Super happy with this product. But I am curious, will this product keep my EGR pipe from heating up and melting the wiring harness on my rig?
Thanks
I now have the correct plugs to make these for 93-94 and will be building up some this weekend. 95-97 have been in use for some time and are working well.
I have a ‘94. Have replaced all EGR components with new OEM except a used sensor off a functioning engine. Still getting error codes for EGR! I live in Ca but in a county not requiring smog checks. Can I simply use your bypass plug and not block the vacuum tubes? I do not think I care about EGR functioning, I just want the CEL to go away. It bugs me. Will I cause a problem leaving the EGR intact except bypassing the sensor? Thanks for any advice.Yep, it should.
The plug alone should take care of the code.I have a ‘94. Have replaced all EGR components with new OEM except a used sensor off a functioning engine. Still getting error codes for EGR! I live in Ca but in a county not requiring smog checks. Can I simply use your bypass plug and not block the vacuum tubes? I do not think I care about EGR functioning, I just want the CEL to go away. It bugs me. Will I cause a problem leaving the EGR intact except bypassing the sensor? Thanks for any advice.
John
3.5mm. OEM is 90999-92003 or -92004I've had this since they first went up for sale with no issues, love it. I recently moved to a state with emissions. I think I want to reactivate the EGR for my best chances of passing the NOx tests and possibly the visual inspection. Has anyone successfully removed the ball bearings from the hoses? I'm wondering if replacing the hosing might be easier. Does anyone know what size hosing I should buy?
You passed emission testing with this installed? Did you see an increase in NOx levels?Does it make sense to delete the modulators and block off the pipe? Or just leave the ball bearings in the vacuum lines?
This kit has been working for me for quite some time along with passing my last smog test.
I passed with mine installed... but I also live in a state that doesn't measure nox... or really do anything but plug in OBD 2 and check for codesYou passed emission testing with this installed? Did you see an increase in NOx levels?
There are lots of rigs passing emissions with these installed.You passed emission testing with this installed? Did you see an increase in NOx levels?
Seems that way. Mine is still pretty low miles (<170000) and has never failed. Seems like I need to solve the current P0401 code first? I just need to wait for the temperature to drop below 10,000 degrees here first.There are lots of rigs passing emissions with these installed.
Hey, I just wanted to clarify some confusion I'm having about "readiness." Once this test plug is installed and everything is A OK, does unhooking the battery, for whatever reason, revert the system to "not ready?" Do you have to return everything to stock/normal and run some drive cycles to remove that code?Seems that way. Mine is still pretty low miles (<170000) and has never failed. Seems like I need to solve the current P0401 code first? I just need to wait for the temperature to drop below 10,000 degrees here first.
That was kind of my question I guess. My EGR system is "in readiness", no codes, so I'm ready!You may never have readiness. The plug handles the light/code but not readiness. If you start with readiness when the plug is installed it will maintenance readiness, if not the code/light will clear but you won’t get readiness. In order to achieve readiness you not only need the appropriate drive cycle but another set of relays to deal with the ECM requirements for readiness.
That stuff is mentioned earlier in this thread, but here is more readiness info too. EGR Readiness Achieved with EGR Removed! - https://forum.ih8mud.com/threads/egr-readiness-achieved-with-egr-removed.437888/page-5
