Yes it cleared mineDoes this cure the p0402 code as well ?
So 100 miles or there about and I get the CEL come back on with the p0401 again!Your idle should not have dropped. I would also get your resistor waterproofed. You will end up getting water/corrosion in your main harness, possible.
Is the 4.7k ohms resistor 1/2 watt ?
Thanks
That's what it says on the packet they came in 4.7k ohms 1/2 watt. What I got there was a temporary set up, I did plan on pulling the temp sensor harness and using that plug to solder the resistor in and make it permanent. Have you looked at the pictures for my vacuum hoses? I've just doubled everything back on itself! Not sure if that's correct or not.Yes 1/2 watt is fine. Put an ohm meter on your resistor and check it. I'm not really a fan of those little crimp connectors like your using there. If it checks out and you are sure you have done the rest correct, start working down your harness as you may have an issue in the wiring. That is very rare, but it does happen.
The colors on that resistor look suspect to me too. Make sure you have the correct one.
Order kit. Took care of my 401 code.
This look super
I‘ve a 94 OBD1 throwing a 71code (EGR).
Would this test connector neutralize my current CEL status to allow further testing?
TIA
Thank you kind Sir.....I’ll be visiting your site directlyYes, yes it would![]()
