Well I guess I could spend more time over in the 25 section but being lazy and an opportunist I’ll just ping herein. And it is about the topic sort of anyway...
@Splangy the 25’s don’t have hi/lo gearing in 4wd? Just a single gear?
I assume your referring to Lo as 1st? I have the same equipment. Every time my wife pulls a tight corner in 3rd(1:1), I have to fight the urge to explain why that isn’t remotely ok. Transmissions are cheaper than lawyers.View attachment 1975114
Never use 1st on street. Typically 2nd even on upslope ..... 3rd if downslope. 350 with sm465 running 35s and 3.70s. Drives easy!
Even with a synchronized 4 speed - my truck generally decides when it does or doesn’t want to be in first gear. I’d say 20-30% of the time from a stop, I have to hit the clutch a couple times for the shifter to drop into first. Sometime I have to shift to second, then first. If it’s being stubborn sometimes I have no choice but to start in 2nd, but when I DO have a choice - I start in 1st
Correct. Just 2wd/4wd. No low range. First gear is something silly like 7:1 so that helps.
If you do not plan on repairing or replacing your transmission I would learn how to double clutch
What sliders are those?View attachment 1975114
So this is semi related back to my original post on this thread - how difficult is it supposed to be to get a synchronized 4-speed into first gear? I occasionally have a lack of “mesh” and a lock out even on my 2009 Mazda, but it seems quite a bit more frequent in the H42. I also feel like spooling up the synchros to mesh on almost any downshift is a particularly slow and noisy affair. I’ve never been certain if this was a normal phenomenon of an “old slow truck transmission” or if my transmission is worn/tired.
I saw this post and thought maybe it was considered “normal” but it seems like the jury is split.
Rick
If an H42 doesn’t want to make a clean downshift into first, something is wrong. In my experience, it is one of four things. One: binding of the pilot bearing/ bushing which does not let the input shaft ‘spool down’ when the disc is disengaged from the flywheel. Two: inadequate disengagement of the disc because of inadequate movement of the throwout bearing. Three: improper clearance between the input and output shafts not fully releasing the 3rd or 4th gear synchros. Four: failing 1st/2nd synchros.
Because it is a synchronization symptom, people are quick to diagnose the 1st/2ndsynchro. Too quick IMO.
Gr8Pmkn, they are custom built sliders. I will send detail pic tomorrow. The foot steps are bolt on for my wife. She’s to small to easily climb in. Ran step on her side only until I became tired of being asked did I know that my side had fallen off.What sliders are those?
