Events/Trails DIY Turbo V1.0, Boosted 80 = Happiness
Offroad Events and Trail Reports
some sort of rear mount snorkle, some shielding and maybe a water to air i/c and it should do fine inthe mud or water. maybe some ceramic coating could help stock anycracking when doping it in cold water.
I have actually seen a few Jeeps and 4Runners with this type of Rear Mounted System driving across rivers. Same as your muffler and exhaust being submerged.
Chances of this on a OBD1 cruiser?
I'm game to try it. Mostly the same setup except for fuel delivery which may or may not need some tinkering. Once I get this setup finalized, I plan on building it on a few different applications.
This would be a good option for us Cali residents with the smog inspections. On the books, anything mounted after the factory cats, is not considered in the inspection process. All you would have to do is remove the turbo intake charge piping and install the factory elbow. It might raise an eyebrow, but legally they couldn't do anything about it.
Will you be testing this on a factory cat setup, or have you modified that area for exhaust flow?
I installed a 3" Random Technology High Flow Cat followed by a 2.5" OBX Stainless Muffler and continued with a 2.5" pipe all the way back to the turbo. You can leave the factory cats and remove muffler and go straight pipe back to the turbo. The turbo reduces exhaust tones tremendously. I plan on running this by the local smog shop I deal with and see what numbers come back and compare them to the smog I did a couple months ago when I purchased it with the factory cats on and no turbo.
Very out of the box thinking, good job! Looking forward to your future concoctions!!!
Thank you sir. The Gears are always turning.
awesome
would be nice to have some sort of intake tube run up inside the back against the rear most pillar and out the roof with a scoop
awesome
Ya, I thought of that too, however I did not really want to cut into any of the metal.
I plan on making another version which will connect up to the factory air system so that you can use factory style snorkels. But adding a snorkel on the back would definitely get some attention.:p
awesome
You know, would it be too much of a redneck if you ran a 3" pipe straight up the C pillar (or is it the D pillar) into an ARB snorkel ram head? :hillbilly:
Yes it would and I think it would work great and be a shorter run
Or somehow utilize those vents behind the rear sliding windows or atleast from that location with a side mounted scoop on the side of the truck where the vent is
Just a thought, I know nothing about nothing
If rednecks can have smoke stacks, we have a fresh air snorkel stack....BOOOOYEAHHHH bitches....
Don't temp me, I might just put up a 6ft stack with a 2ft wide mouth on the end.
This is getting seriously interesting. I'm very curious to know how this comes back from your local smog shop! Also, thanks for the reply to the PM. Absolutely AWESOME.
My interest is piqued on this as well... definitely keep us posted. If a kit is in the works, let us know when it will be available (OBD I/ OBD II).
I recall an episode of Trucks on Powerblock TV, where a Taco used this type of turbo in the rear of the truck. Of course they did the whole thing in like 22 min but the results were hard to argue against.
Getting back to the redneck-esque of the air intake, how about if a 3" tube go from the turbo inlet to the rear cavity (where the jack or the sub-woofer are kept) and terminates there. On the outside of the rear Q panel, one of these pokes out sideways?
Yeah if this thing passes CA smog, biggest loop hole ever! Would work great for you CA guys. I think with an extended intake it could be good but I would still be very worried about water crossings. I don't think dunking a turbo is anything like dunking a muffler. They can run as hot at 1500 degrees, then dunking them in cool/cold water, with precisely machined parts with tolerances in the thousandths spinning 100,000rpms, I don't see it ending well but would love to be proven wrong. :)
