I have a question on this whole process in general. What are the limitations of these systems? I ask as my father in law has a 72 International Loadstar 1700. It is a single axle dumptruck, an old Colorado DOT truck actually, has about a 10 foot blade on the front, 2WD. Moving down the road, or if the snowplow is off it steers pretty well. But in tight quarters, trying to maneuver, especially while plowing it about pulls your shoulder right out of the socket. Everyone that has ever had to plow with it through the years has thrown a rib out trying to armstrong the damn thing.
Finding the proper power steering box for it and such is difficult. I looked at some inline hydraulic solutions, similar to the electric motor of these systems. I'm wondering if a cheap ebay eps system would give the needed assist to make this truck easier to use. Don't want to spend a lot on it, it is just a farm truck, but it would be nice to have some steering assist.
It uses a manual box and linkage setup similar to the early Toyota pickups. Of course everything is bigger, but the steering shaft is your typical diameter and setup. I would think the mechanical advantage is in the steering box itself, so if these electric systems provide assist to the torque you apply at the wheel, does it matter what size tire you are moving. If a person can move it manually, I would think these could assist just about any mechanical steering box.
Any thoughts on the limitations of these systems in these types of applications. Sounds like the results people are getting on 40's is promising, and actually in certain situations, I bet I didn't apply much more force to turn the wheel of a 40 as you do to turn this dump truck.
