- Location
- United States
UPDATE: See most current post, this is no longer a part-out, it's a mostly complete engine! Some details changed below to reflect this.
After a lot of work (and a lot of struggling), Iam parting out selling my 1HZ. The history on the engine is fairly well documented in here (Excessively-underpowered-1hz-poor-fuel-economy), but the short of it is as follows.
I bought this engine in a running state but with unknown history. It had a gummed up fuel pump which some hills and lack of EGT gauge caused the piston to chip and break a ring. I rebuilt it and added a turbo while I was at it. Something went wrong with the oil pressure and one of the BEB's shredded and made its way throughout the engine giving it a knock as one of the rods ground away at the crank and the piston scraped away at the cylinder walls. SEE UPDATE.The block was bored to the Toyota manual max so it is probably scored beyond wanting to attempt to use, and given that I can only guess at what caused the failure, I would not recommend running the block. The bearing material also made it's way to the cam and scored both the cam and head. Again, I would not run these unless you know a magic way of repairing (though I'm guessing it's probably cost prohibitive).
A few things to note:
1. I would highly prefer to sell this engine as a package deal so preference will be given to any such offers.
2. Photos of most everything are here.
3. When I bought a replacement engine, I swapped some of the newer parts I had purchased for what was on the 1hd-t I picked up. These should all function the same, just not as new and shiny as the photos of tear down show. Please keep this in mind and pay closer attention to the photos of individual parts.
Here's a general list of what I have available for sale and/or some specific things I should call out:
-Injection pump. Fully rebuilt with a new boost compensator by Diesel Fuel Injection Service in Oregon. If you're going to have a pump rebuilt, these are some of the best guys in the states.
-Injectors and lines. Again, fully rebuilt by Diesel Fuel Injection Service. I will be dropping these off with them again next week to get tested and rebuilt again if necessary.
-Air Conditioning pump, bracket and lines, but no condenser.
-Crankshaft - not from this engine. I picked it up from another mudder who ended up getting a short block and didn't need it.
-Choice of 6 1HZ connecting rods or 5 good and 1 bad 1HD-T rods. The 1HZ rods were pulled from the original engine when I rebuilt it with 1hd-t rods even though the original rods checked out good at the machine shop.
-Choice of 1HD-T or 1HZ Crossover pipe or 1HZ.
-Choice of Exhaust manifold - 1hz and 1hd-t
-CT26 turbo from the 1hd-t I purchased. Sorry, I had the Grunter rebuilt and I'm keeping it.
I also have all of the various fittings that came with the Gturbo that make it easy to plumb a 1hz for a turbo. I don't have a photo of the CT26 yet because I just got my grunter back and will be swapping it this weekend.
-Steering pump, vacuum pump, oil cooler, fan, alternator, front and back timing cover plates, gears, and lots of miscellaneous ancillary parts. Just see the pictures.
A couple more side notes I should mention is-- a crank pulley is not included, and while there are a lot of miscellaneous nuts and bolts, some were damaged in removal or I needed them so expect to pick up a few things if you're rebuilding.
Considering my location (Portland, Oregon), the Injection pump, injectors, turbo and the fact that it's mostly complete engine minus the cam and a few ancillaries, I'm asking $3200 for everything plus actual shipping.
So, take a look at the pictures and let me know if you're interested. I have most everything boxed up with lots of protective wrap, but nothing is inaccessible if more photos are necessary. Thanks for looking and let me know if anyone is interested!
Cheers,
Leit
Cheers,
Leit
