Dash Configuration Reference
Matt... Are you trying to show us something specific here? This thread is generally to document stock dash configurations.
10/69 70 model. First year without a throttle cable.chrome plug next to the choke filled the throttle hole.
1966 FJ40
3 speed on the column
ignition key on left end of dash
windshield levers
heater style with detached control knob panel (3 knobs for...?)
4wd engage lever on dash
steering wheel and horn button style
no provision for a radio
steel defrost deflectors at bottom of windshield
3 embossed horizontal stripes across middle of dash
no dash pads
3 dash indicator lights for...?
dash knobs:
"LIGHT", WIPER"...?
View attachment 509944View attachment 509945View attachment 509946
Could you help me to figure out what the knob directly to the left of the 4wd switch does? I have not been able to find anything about what this knob does.
1966 FJ40
windshield levers
no dash pads
dash knobs:
"LIGHT", WIPER"...?
Could someone also send an image of the throttle knob route? Thanks!
what about the one left of the knob that engages 4wd, the 2nd to the left from the lever?
do you mean the right of the knob?
the one with the wavy lines on it?
that is the cowl vent
My mistake I thought you were referring to the pic LITP post # 102
no idea on the one in your pic
I don't have that switch and I don't have a cig lighter on my 1965
cowl vent didn't appear until 66 or 67 with the disappearance of the windshield frame vent
yeah I haven't been able to figure out what it is...
Does anyone know what this knob does on a 66?
Edit: just realized someone asked the same question on this forum. It is the cowl vent.
1966 FJ40
windshield levers
no dash pads
dash knobs:
"LIGHT", WIPER"...?
Can someone send an image of how this early cowl vent knob connects to the cowl vent? Thanks!
Specific issues how this or that works and technical questions you should start a new thread … or if you search there are pics and discussion about it
Hey another late comer, but I didn’t see a pic of the 65 FJ40. Mine has been converted to 3 on the floor so obviously the lever and 4wd is missing. 4wd knob has been replaced with a switch for the horn..weird but whatever. There is also something missing in-between the ignition switch and the left blinker indicator but I think a PO drilled that. Otherwise this is pretty close to stock I believe.
I know this is an old thread, but if anyone gets notified there is a new post in it, mine is a 1971 FJ40 with a build date of December 1970. If anyone could tell me the proper order for that year, I would greatly appreciate it. I am especially curious about the small empty hole to the left of the cig lighter? Wish I had better straight on pics. I'm also curious about the unlabeled lights. To the left of the steering wheel I see the brake light labeled, then there is a light that is not labeled, and a white pull knob? To the right of the wheel, closest to the wheel, are 2 more lights above and below each other and neither of them labeled. And it looks like the paint is gone from the other knobs. It's at the paint shop so I can't look at them to see if I can tell what they are, so if you know, please share.
Thank you.
@Living in the Past - Your dash layout looks the closest to mine.
What is the red button or pull knob to the left of the cig lighter? And is it a push button or a pull knob?
Then on the bottom row, what is the small black one on the far right? The 2 "H" pulls must be the heater, front and back. Which is front, and which is back?
On the far left you (and I) have 2 lights, 1 above and below each other. What are each of them?
Then to the left of my wheel, I have a light labeled Brake, but to the right of it is another light that is not labeled. Do you have that too? If so, what is it? Also to the left of the wheel is a white pull knob. Do you have that, and if so, what is it?
Thanks
