Dash Configuration Reference
FD is connect to a cable that operates a vacuum switch for four drive when pulled. Two wheel drive when pushed in. The ball below is used for high, range/neutral/low/range. It has pin out the side of the lever to pull the FD knob out when in low range. The lever is connected to a rod running behind the dash. It's this rod that needs to go when cutting a hole for a radio.
Better picture of the ball and lever
Plug for the light will be close to the heater hoses.
Thought I had photo of the plug on my phone but didn't f see it. Here is the vent knob.
Mine has the FD pull, but not the cowl vent pull to the right of it. So I wonder where it is?
8/71 if you ignore the improvised dash pad cover and the temp gauge below the drivers left pad it should be close to stock. The empty hole next to the hazard light pull is the lighter socket. That knob is in the glove box.
There are two blanks. One between the choke and the hazard that was the hand throttle? And one on the far right past the glove box that was the soft top light?
HTH
View attachment 515748View attachment 515749
My 1970 FJ40 has the same knob protruding from under the dash just to the left of the heater. What is that knob for?
Thanks for the reply. I am in my first attempt at a body off restoration and I am in the tear down mode. I am trying to understand what all the knobs do for when I put it back together. So, the knob I was referring to is the ball shaped knob just to the left of the FD control switch.
1966 FJ40
3 speed on the column
ignition key on left end of dash
windshield levers
heater style with detached control knob panel (3 knobs for...?)
4wd engage lever on dash
steering wheel and horn button style
no provision for a radio
steel defrost deflectors at bottom of windshield
3 embossed horizontal stripes across middle of dash
no dash pads
3 dash indicator lights for...?
dash knobs:
"LIGHT", WIPER"...?
View attachment 509944View attachment 509945View attachment 509946
I love the simplicity of the '66. I have a '70 and it is still pretty simple, but not as simple and nice as yours!
