Choke cable variations
Those are nice Matt! You should post the Def knob you did for me and my cig lighter— now those are FLY! Am quite certain you are up at 1:30 a.m. EST
I'm sure that many Cruisers have had the choke cable replaced over the years. My 2/71 has an early choke cable installed. No idea which PO did it. It wasn't my brother or me.
Questions about the 82-84 illuminated choke cable. Same bulb as a headlight switch by chance?
Anyone got one for sale or have a good picture of one?
I restored 2 Illuminated choke cables
the one with the text word CHOKE is For a 1983-1984 FJ40
The Font LOGO is a FJ60
i think o_O
This 1978 FJ55LG-KA is the KING of Choke Cables
- Measuring 97cm , Only the FJ60's is longer , But not nearly as heavy duty
- New Stainless steel Strand wire Cable
- New Black Outer Cable Housing Liner
- New solid Brass Ferrel End Cap
- Last 3" inches of cable Brazed Solid
- Knob, Guide Tube , Aluminum trim bezel , Hex Nut All Fully Restored
- Final cable step , Lube w/ T-9 Boe-Shield
- apply site protection New bag to Knob prior to shipment :)
1985 FJ60 USA Spec. Non-Illuminated Choke cable assy Kit :
- This was one of the More Challenging Choke cable Jobs i have had in a while
- I was able to source the Main Choke cable assy new with little effort
- But the Knob & Retainer ring nut proved to be a challenge
- I got the inner-web & started to Hunt , I found myself on Ebay.com/Costa-Rica
- i quickly found a Knob and Buy It Now , shipping took about a week , oddly enough it is a USAv spec. knob with the Text Word CHOKE on it
- i started calling ALL the usual and not so Usual USA Land Cruiser parts Vendors for the trim ring nut , i got Lucky with one , they had several
NOS ones , so i bought all they had in-stock for future jobs
This is a 1971 40 Series Throttle Cable
- Fully restored back to period correct spec's
- New coil spring Liner housing w/ modern Nylon core for better then NOS gliding in and out
- New Solid Core cable wire
- Steel & Brass Guide tube polished Out " Bright " & Low temp marine grade Low luster clear Baked on
- Knob details Text Font Logo are very challenging on this style / year era cable due to there small size , so Hobby Grade
Magnification Glasses had to be worn in this phase
1 set of 3 Fully Restored Cables for 1 mans truck ...............o_O
_____________________________________________________________________________
- I Alloy Base ( max troy weight / super high strength ) Silver Solder Solid , the last 3 inches of My Upgraded Stainless Steel Stranded Cable for early Set Screw Type carbs , No More Fraying after repeated Phillips head cinch-downs
Dude... this is a priceless tip! I'm doing this ASAP!
Patina anyone ....................... ? :)
1974 FJ55
