It's a forum server issue, not an operator issue.
You should see all my messages I have for parts I am selling. They are a mess now lol.
. Oops! Can't seem to find a way to delete them
This connector seems bad lol. The plastic fell apart leaving the terminals, where can I buy the female connector? I'll go ahead and order the sensor
Pulled the ignition wires one at a time to see if one wouldn't change idle. Cyl #6 has no change when removed,
When measureing exhaust manifold temps, #6 was also significantly cooler than the rest. sitting about 260-270F whereas all the others are 330+F
Just a quick question, After you replaced your ECM did you ever go back and verify by measuring your exhaust manifold temps that cylinder number 6 was working, and its temps were close to the same as the other cylinders?
