Bosch iBooster Brackets for 60/80 Series – Tested in Moab, Ready to Go
Info from a website talking about the ibooser:
: What happens if I loose electricity? Do my brakes fail?
A: No! The pedal is connected to the master cylinder via a pushrod, exactly the same as vacuum boosted car. Should the electrical circuit be interrupted you would simply have manual brakes, precisely the same as if a vacuum booster failed. If you think about it, if you lose electrical power you've likely lost power to everything, the engine dies and with it power steering and all accessories. Vacuum or electric you'll still have manual brakes though.
We have two FJ60 Cummins 6BT5.9 swaps and one FJ40 4BT swap and definitely could use this booster adapter. Which booster are you using?
Yeah I would love to know if this would fit in a pre-boosted 40 with the firewall rib. :)
There’s a thread on Irate4x4 with basic cad files so you can 3d print to check fitment.
Oh cool! Thank you, I’ll go check it out. I bet it won’t fit…. But maybe? :p
there's no way it will fit in the stock location. But remote... :hmm:
Definitely interested in this for my 60. I havent gone down the rabbit hole of research yet, but is there different iboosters?
Can this also be used as a parking brake, or would it consume to much power with the car off, stupid question but would be cool when wheeling to be able to have all four wheels locked when getting in and out of rig to check trail lines.
Excited to see the bracket you guys make!
@torfab Please let me know when you are ready to take orders. I’m actively building this system now with the Gen2 booster. I’d be on board for a turnkey mount that’s already been sorted for my 80.
@torfab I saw the brackets are live on your site.. Awesome product and thanks for bringing it to market. Can you provide a part number or similar for the ibooster you're using? I am not very familiar with them and if there are differences?
I’m in for one of these. Copied info x Cross posted from the 80 thread. Hopefully less jumping around for people.
“I expect to be able to fill a few more orders by mid-late July at this point. I have a few components still being manufactured. Thanks for all your support for Torfab!”
Torfab Landcruiser iBooster Adapter - https://shop.torfab.com/products/torfab-landcruiser-ibooster-adapter?variant=50792999977127
Gen 2 iBooster Vehicles
  1. Honda Accord - this is the only Tor tested so far
  2. Tesla Model 3
  3. Tesla Model Y
  4. Renault Zoe (2018+)
  5. Renault Captur hybrid (2020)
  6. Renault Clio V hybrid
  7. Citroën DS 7 Crossback
  8. Peugeot 3008 II
  9. Volkswagen Caddy Cargo V
  10. Porsche Taycan
  11. Toyota Yaris IV hybrid
Honda Accord iBooster. Seems cheaper than buying a Tesla iBooster.
I just ordered this from Ebay: 2018 - 2020 HONDA ACCORD 1.5L ELECTRIC BRAKE BOOSTER 46000-TVA-A090-M1 OEM”
Wiring harness Tor suggested:
Shared info on iBooster:
We have, 40a fuse to the battery, ground to the body, then ran a wire to ignition.
It's mentioned above that the booster works with the engine off - a big advantage over a vacuum booster. That is probably fed via the constant 12V and ground wires. So what's the ignition wire for?
Works like manual brakes, same as vacuum. If you lose power, you’ll have brakes, you’ll just have to push real hard same as if your engine dies and you have no vacuum.
The ignition wire wakes it up, when ignition turns off the booster turns off. One little nice quirk though, when ignition turns off the booster stays awake for a minute or so and stays awake if you keep pressing the brake pedal. It turns off completely when it sits idle long enough.
