bolt size
Battery pedestal to frame bolts? There are 6 total; two down from the top of the frame and 4 on the inside of the frame rail.
I know they are m8x1.25 but I don't know the 'correct' length and / or if the lengths differ based on the above.
91651-40825 = 25 mm in length
1920452
Ok thanks and im assuming bolt are bolts and Not specific to the hardware store u shop at lol
Toyota uses JIS standard and there are specific sized bolt heads for each thread size. Even what looks like Phillips are not Phillips and a normal Phillips screwdriver won’t work as well as the JIS driver.
ok ill see whT wrench works
@dchall360 :
With the JIS heads? Wish they carried them around here. Nothing is more annoying on these trucks than the random 13mm bolt head.
What we're trying to point out to you that standard hardware store metric fasteners ARE NOT JIS specification, which means the OEM FJ40 bolt head sizes are different that standard metric hardware.
For instance, the M8 x 1.25 bolts in JIS have a 12 mm hex size, whereas standard hardware store will have 13 mm hex size.
JDC1 is pointing out switching between 12 and 13 mm wrenches, and 14 and 15, and 17 and 19, is a high price to pay if you intend to settle for standard hardware stock.
JUST an FYI. :)
@dchall360 :
JUST an FYI. :)
Without seeing your rig, paying attention to the small details like using JIS hardware will add to or maintain the value of a somewhat rare and valuable vehicle. Especially with the corrosion that we have to deal with in the rust belt.
Belmetric is also a good source for hardware.
Ok thanks and im assuming bolt are bolts and Not specific to the hardware store u shop at lolw
You assume incorrectly. There are many different materials, standards and strengths available. The wrong bolt in the wrong place can lead to catastrophic consequences. Would you use a class 4.8 bolt to hold a brake caliper on?
Besides the obvious strength example above, any restoration looks half-assed when you see hardware store hardware. It can be a very distracting lack of detail in other-wise quality restoration.
In regard to standards, it’s irritating as hell to work on a truck that is half JIS and half DIN. Nobody expects to find a 13 or 15mm head after they’ve crawled under the truck with their 12mm and 14mm wrenches.
Only holding on grill screen lol not a brake caliper and the hardware store bolt head is same as original except for not having the philips screw. Groove in head plus u cant even really see them after radiator is installed
For my restoration I bought a bolt kit from Daveworks and I also sent a bunch of original hardware to be replated. It is well worth the cost to have everything go back together with new matching fasteners. The JIS screwdrivers are a must for working on any Japanese car or motorcycle.
