Search for coolerman and on his signature line he has a spreadsheet with bolt sizesneed size bolts for battery tray bracket to body/frame and size of bolt for bracket that hold coil bracket to engine thanks
I just updated the spread sheet with MANY additions... I had not updated it since 2016!
The factory bolts holding the rear combination light bracket to the rear frame member are part no. 91651-40820, which would be M8-1.25, 20 mm long with integral flat and lock washer.Bolt size 1971. Rear taillight brackets do not See it listed
I’ve been using this daily lately while reassembling my 67. It is priceless!!
I was talking about the grill mesh thats in front of radiator. The mesh that the Toyota letters mount to thanks for your help i appreciate itJust added the tail light bracket to frame bolts.
The Bib grill mounting studs ARE listed (Line 110) as 6mm x 1.0 x 15mm so they take nuts that are 6mm x 1.0 with 10mm heads.
I just added the nuts as a separate item. Line 111.
Hardware store around thr corner has all these stainless or regularNot sure where you are sourcing your bolts but @davework is a Mud vendor and has a great selection of JIS hardware.
Overland Metric | JIS Hardware
At Overland Metric we've spent the last seven years learning the business of Toyota Land Cruiser and JIS hardware. In 2016 we expanded the business from Full Vehicle Kits to include Stainless Kits and Bulk Hardware. We spent six months with manufactures to duplicate OEM hardware as closely as...www.overlandmetric.com
