bent steering tie rod
Powell River, BC
Pretty sure this stuff shouldn't be shiny....
I think Slee has stronger replacements
I run a heavy duty marlin crawler tie rod. From your picture it doesn't look like the tie rod is bent. It seems to have made contact with your sway bar. Does it drive fine? The stock tie rod is pretty beefy, unless you are playing in rocks I have a hard time seeing how you bent it.
Oh the rod was bent for sure, probably by about 20 degrees. It did drive fine, wheel was a tad crooked. It's been like that for awhile and never thought much of it till I was underneath today bolting a skid plate back on and noticed all the shiny marks.
My vice laughed at me as I attempted to bend it by hand..but a good hydraulic press took care of things quite nicely.
I bent my tie rod pretty bad about 2 months ago. Although it seemed to drive okay, I had new-ish tires that I need to last a good while and I did not want any alignment issues ruining them. I replaced the tie rod and tie rod ends with the MOOG replacement part (
MOOG ES3563A) off of RockAuto. Parts were made in Japan, and fit right in.
bent steering ...
Amateur!:hillbilly:
file.php
We replace with stock, would rather bend rods than break the sector off, shear knuckle studs, etc. Bent rods are pretty easy to fix on the trail, the others, not so much.
I don't seem to remember my sway bar ends being bent like that...
Mine are, I just checked. But my tie rod is a little farther away from the dif housing. Looks like did is pointed up kinda high? Mine is lower with old Slee arms, which net 2 degrees of positive caster. Did you trash your front radius bushings??
These look to be about $25 each.
Never heard bad about Three Five - Made in Japan
Cruiser Outfitters
Thanks for posting our link.
We have the joints as a set, individually, OE tie-rod & drag-link tubes and HD tie-rod components too!
^^^^ One stop shopping, done!:hillbilly:
I bent mine a few years back and had to replace it. It was hell getting it off the vehicle because it was bent where it is threaded. Not sure how I did it but I'm more about getting there and less about taking the most difficult line. I probably just slipped off a rock. I replaced with another stock one.
